irose57
RPI3 acting as DHCP Server
Sun Apr 09, 2017 6:09 am
Hi - I'm new to all this but I have an issue where my Pi is acting as a DHCP server on my network. It's allocating addresses to devices that get turned on rather than my router. I've tried searching for ways to disable this to no avail.
I tried dpkg -l | grep -i dhcp and got the following:
ii dhcpcd5 6.7.1-1+rpi5 armhf DHCv4, IPv6RA and DHCPv6 client with IPv4LL support
ii isc-dhcp-client 4.3.1-6+deb8u2 armhf DHC client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.1-6+deb8u2 armhf common files used by all of the isc-dhcp packages
ii udhcpd 1:1.22.0-9+deb8u1 armhf Provides the busybox DHCP server implementation
Tried sudo update-rc.d udhcpd disable but got the following.
update-rc.d: error: cannot find a LSB script for udhcpd
Help much appreciated!
SurferTim
Re: RPI3 acting as DHCP Server
Sun Apr 09, 2017 11:37 am
I haven't tried this, but it should work if you don't want to remove the udhcpd package.
Edit the file /etc/default/udhcpd and change the line:
#DHCPD_ENABLED="no"
to
DHCPD_ENABLED="no"
or add that last line if missing.
epoch1970
Sun Apr 09, 2017 11:38 am
Welcome.
I would try this to identify who is serving dhcp leases on the Pi:
admin@cassis:~ $ sudo lsof -i udp:67
[sudo] password for admin:
COMMAND  PID    USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
dnsmasq 1950 dnsmasq    4u  IPv4  12457      0t0  UDP *:bootps
admin@cassis:~ $ ps w 1950
  PID TTY      STAT   TIME COMMAND
 1950 ?        S      0:05 /usr/sbin/dnsmasq -x /var/run/dnsmasq/dnsmasq.pid -u dnsmasq -r /var/run/dnsmasq/resolv.conf -7 /etc/dnsmasq.d,.dpk
As you see in this case it is dnsmasq.
And if you want the deluxe edition:
admin@cassis:~ $ sudo apt-get install apt-file
The system-wide cache is empty. You may want to run 'apt-file update'
as root to update the cache. You can also run 'apt-file update' as
normal user to use a cache in the user's home directory.
admin@cassis:~ $ sudo apt-file update
admin@cassis:~ $ sudo apt-file search /usr/sbin/dnsmasq
dnsmasq-base: /usr/sbin/dnsmasq
So if I wanted to remove that executable I would try to "apt-get remove dnsmasq-base".
HTH
mfa298
Sun Apr 09, 2017 3:21 pm
irose57 wrote: Tried sudo update-rc.d udhcpd disable but got the following.
On a recent (Jessie) version of raspbian try using systemctl instead - this should work for systemd services (the modern way of doing things) and legacy init scripts.
sudo systemctl disable udhcpd
sudo systemctl stop udhcpd
Of course, if you don't need that package installed (I don't think it's installed by default) you could just 'apt-get remove' it
epoch1970 wrote:Welcome.
For an installed package you don't even need to install apt-file, just use (I've got the isc dhcpd server installed rather than dnsmasq or udhcpd)
pi@pi2:~ $ dpkg -S /usr/sbin/dhcpd
isc-dhcp-server: /usr/sbin/dhcpd
irose57
Mon Apr 10, 2017 1:27 am
Thanks for the replies.
Will try
Will let you know how I go.
