mmaceachran
Remove openJDK and add Oracle
Sun Apr 09, 2017 12:14 am
I have a Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
It aparantly comes with OpenJDK 7 when I run the java -version I get this:
java version "1.7.0_121"
OpenJDK Runtime Environment (IcedTea 2.6.8) (7u121-2.6.8-2~deb8u1+rpi1)
OpenJDK Zero VM (build 24.121-b00, interpreted mode)
I tried running sudo apt-get install oracle-java8-jdk but I get this response:
oracle-java8-jdk is already the newest version.
so it seems that i have that too... ? Can someone explain what is happening here?
Can someone tell me where the Oracle Java is, how do I remove OpenJDK 7, and set my JAVA_HOME to Oracle 8.
Re: Remove openJDK and add Oracle
Sun Apr 09, 2017 10:12 am
mmaceachran wrote:I have a Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
Have you fully updated Raspbian Jessie with Pixel, if that is the Operating System installed ?????
sudo apt-get update
sudo apt-get dist-upgrade
I have installed no extra Java related packages and the following:
uname -a
java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
Searching for packages I have "oracle-java8-jdk Java™ Platform, Standard Edition 8 Development Kit " installed
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
Return to “Java”
Who is online
Users browsing this forum: No registered users and 3 guests
