yoyoRPI3
How to stop N cores of the cpu [solved]
Sat Apr 08, 2017 11:25 am
Hello guys,I want to utilise only 2-3 cores of my rpi 3 because i don't need much power.How can i stop some cores of the pi 3?THanks
yoyoRPI3
Re: How to stop N cores of the cpu
Sat Apr 08, 2017 12:22 pm
EDIT:I found a solution:add maxcpus=N in the cmdline.txt where N is the number of cores from 1 to 4
mahjongg
Re: How to stop N cores of the cpu [solved]
Sat Apr 08, 2017 2:23 pm
does it now also use a lot less energy (the only practical benefit I see), or are the unused cores just idling, but still using the same amount of power?
Martin Frezman
Sat Apr 08, 2017 3:29 pm
Could also be a heat issue.
If this post appears in the wrong forums category, my apologies.
