di512
xorg
Sat Apr 08, 2017 9:00 am
Hello.
I have 2017-03-02-raspbian-jessie-lite installed. The problem is Xorg won't generate own config.
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux rpi3 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l
Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 dma.dmachans=0x7f35 bcm2709.boardrev=0xa02082 bcm2709.serial=0x22dee2e4 bcm2709.uart_clock=48000000 smsc95xx.macaddr=B8:27:EB:DE:E2:E4 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 8 11:44:56 2017
List of video drivers:
modesetting
fbturbo
No devices to configure. Configuration failed.
(EE) Server terminated with error (2). Closing log file.
buja
Re: xorg
Sat Apr 08, 2017 2:19 pm
Jessie Lite is light because it doesn't have a GUI (xorg etc.).
If you want a GUI it's a lot easier to install full Jessie.
If you really want to have a GUI on Jessie Lite, this guide will get you going: viewtopic.php?f=66&t=133691
di512
Re: xorg
Sat Apr 08, 2017 6:28 pm
Now I have GUI on Jessie Lite. Looks like xorg works without /etc/X11/xorg.conf.
Your link must to be included in FAQ.
