Frank Buss
Re: Gertboard
Wed Mar 28, 2012 4:52 am
You don't need a reflow oven for soldering SMD resistors. I think it is even easier to solder than through hole components, if it is some reasonable size, like 0805 and not 0201.
Gert van Loo
Re: Gertboard
Wed Mar 28, 2012 5:58 am
That is exactly why I made then all 0805 or bigger.
naicheben
Re: Gertboard
Wed Mar 28, 2012 7:19 am
Gert said:
naicheben said:
To the Wiki?
http://elinux.org/Special:Upload
It won't let me.
I keep gettng an error message: "Files of the MIME type "application/zip" are not allowed to be uploaded."
There are only .c/.h files in there and a Makefile. It also refuses if I omit the makefile.
Same here. I can't upload ZIP. It even detects application/zip if I rename it to bla.zip.txt
Does someone know who manages the wiki?
domesday
Re: Gertboard
Wed Mar 28, 2012 7:49 am
OK Thanks for the reply, for future production runs it might be worth noting that many PCB manufacturers will include SMT resistors and capacitors in their production for a very modest fee.
effbiai
Re: Gertboard
Fri Mar 30, 2012 7:41 am
Gert: Upload it to dropbox or the rpi download section http://www.raspberrypi.org/downloads
Edit: http://downloads.raspberrypi.org/tools/ ... emo_sw.zip
msillence
Re: Gertboard
Wed Apr 04, 2012 9:45 pm
Gert said:
Now all I need is a suggestion where to upload it to.....
Why not upload it to github, zip files of source code aren't really what wikis are about. Though you can change the settings to allow them.
domesday
Re: Gertboard
Thu Apr 05, 2012 12:13 am
In case you missed it the demo code is available at http://downloads.raspberrypi.org/tools/ ... emo_sw.zip
Ferret141
Re: Gertboard
Thu Apr 05, 2012 8:22 am
Source forge anyone?
domesday
Re: Gertboard
Thu Apr 05, 2012 3:26 pm
Gert
I notice you have used 74AC244 buffers on the Gertboard, does it need to be AC or could we use the cheaper HC version ?
Gert van Loo
Re: Gertboard
Thu Apr 05, 2012 3:28 pm
Darren said:
Gert
74xx244 so anything you want provided it runs of 3V3. I used what I had laying around. I will be working on the manual over the long weekend.
domesday
Re: Gertboard
Thu Apr 05, 2012 3:33 pm
Gert said:
Darren said:
Gert
That is great news as the AC logic is not as widely available as HC.
Gert van Loo
Re: Gertboard
Fri Apr 06, 2012 5:20 pm
I am preparing for the release of my gertboard. I was writing the manual and as there have been a lot of requests for more details I decided to produce a separate overview of the I/O capabilities. See the document linked below.
Post edit: I put a link in here but that was no so successful. Showed the whole document but in unreadable small format.
Follow this: http://www.scribd.com/doc/88286916
gordon@drogon.net
Re: Gertboard
Fri Apr 06, 2012 5:44 pm
Follow this:
Great stuff, thanks! (It downloaded as a PDF for me)
Gordon
Gordons projects: https://projects.drogon.net/
bill
Re: Gertboard
Fri Apr 06, 2012 6:45 pm
I think that should read (Multiwatt11 package) not "(Miniwatt package)" in the first line under motor controller.
Thanks for the information, I think the board will be a terrific jumping off place for all us hardware hackers. Any chance of getting a full Bill of Materials soon?  I'm sure I and a lot of others would like to start getting the parts together.
Thanks Bill
PS  I hate the "you have a typo or a misspelled word" type posts on the discussion boards but I do want to prevent some beginners from giving up because he can't locate the part.
domesday
Re: Gertboard
Fri Apr 06, 2012 6:47 pm
Multiwatt11 packages are commonly known as ZIP-11.
naicheben
Re: Gertboard
Fri Apr 06, 2012 9:19 pm
oh, I just realised for the first time that the microkontroller is not really nessesarry! On could do without or just with a pin compatible micro extend the board if you like..... shame on me
purvesd
Re: Gertboard
Mon Apr 09, 2012 4:32 pm
Follow this:
Hi Gert,
My friend Steve has a comment regarding your manual where you say (under para on on ATmega device:
"I even slavishly copied the diode in parallel with that pull-up resistor although nobody has been able to tell me what its function is."
The diode is there to provide a discharge path for the capacitor when you power down, so if you turn the power back on quickly the voltage across the capacitor is below the reset level
Gert van Loo
Re: Gertboard
Mon Apr 09, 2012 6:38 pm
Yes, that is why there is normally a diode over the reset capacitor. But in this case there is no reset capacitor. Also you can not place a reset capacitor as that would kill the debug wire function.
All I can think of is that somebody (The first Arduino designer??) did not know enough about electronics so copied the diode from an existing circuit but left the capacitor out not realizing that you can then also leave the diode out. Or maybe there was an RC+diode but then they realized the Cap killed the dbug wire function and removed it, again without removing the diode.
the_summer
Re: Gertboard
Mon Apr 23, 2012 3:10 pm
Don't want to look impatient, but are there any news yet?
cross-keys
Re: Gertboard
Wed May 16, 2012 4:07 pm
the_summer wrote:Don't want to look impatient, but are there any news yet?
Was just thinking the same ... :P
Gert van Loo
Re: Gertboard
Sat May 19, 2012 8:36 pm
Hi guys, I appreciate you all have been patiently waiting and I have not told you much.
Please wait a tiny but longer. Very soon I can tell you what the status is and how you can get your hands on a Gertboard.
dmsuse
Re: Gertboard
Sat May 19, 2012 9:49 pm
$60 and we have to build it ourself is a joke.
wouldn't it be better to post the schematic for the board for us to source our own parts, taking into account we have to build it ourself anyway.
No doubt most people won't need everything on the board anyway, so perhaps do a few different schematics for cut down versions of the gert board.
Re: Gertboard
Sat May 19, 2012 10:00 pm
Where did you get that $60 from?
Gert designed the board so it doesn't need to be fully populated - you just buy the components you want. I guess to buy the PCB and fully populate it might cost $60 but I doubt it.
You will be able to buy the bare board. And I believe there will be options to buy kits of the bits you need, which will probably be cheaper than you can buy them individually.
domesday
Re: Gertboard
Sat May 19, 2012 10:10 pm
jamesh wrote: You will be able to buy the bare board. And I believe there will be options to buy kits of the bits you need, which will probably be cheaper than you can buy them individually.
I think the $60 figure came from earlier in the thread where the estimated cost of parts was £35.Plans may have changed regarding how you can buy the board, you may have noticed that the Raspberry Pi store is not up so I think Gert has made other arrangements.
Re: Gertboard
Sun May 20, 2012 10:03 am
I know what the plans are - there will be an announcement very soon.
