btu
Raspberry Pi 3 heating problem on booting
Fri Apr 07, 2017 4:59 pm
I have bought Rp3 and i have been using it for ten months. Recently, it's processor started to warm-up while i am using it. Yesterday, when i attempted to run it, it didn't boot on startup and it became too hot. When i touched to it approximately a few seconds, my finger became hot as touching boiled water. Also, i coludn't use it since yesterday. What can i do? Can anyone have an idea or suggestions about this trouble?
drgeoff
Re: Raspberry Pi 3 heating problem on booting
Fri Apr 07, 2017 5:24 pm
If within tens of seconds of powering up the Broadcom chip gets too hot to keep your finger on, then the RPi is dead and cannot be repaired.
A frequent cause is electrical abuse of the GPIOs. Did you have things connected to them?
btu
Fri Apr 07, 2017 5:40 pm
Inadvertently, i make short circuit it's 3.3v pin and 5v pin, but after that it continued working. Today, when i try to start the rp3, sometimes it works normally(also it becomes hot)
Fri Apr 07, 2017 6:04 pm
I could fix it, but it's going to cost you about $35 for the repair.
btu
Fri Apr 07, 2017 6:11 pm
I will probably buy a new one. Only i wanna learn the problem that was occurred. Thanks for your attention.
Fri Apr 07, 2017 6:15 pm
When you connect 5V to a 3V circuit you will cause transistors to burn and latch up. That will cause a short circuit on the main processor chip, running the broken chip after that will allow the damage to spread across the silicon until the whole unit is broken.
At that point the $35 fix is to buy a new Raspberry and pay better attention to what you're connecting.
btu
Fri Apr 07, 2017 6:19 pm
Can i try to repair it? Is it possible?
Fri Apr 07, 2017 6:25 pm
btu wrote:Can i try to repair it? Is it possible?
The instructions to repair it are here: http://uk.farnell.com/raspberry-pi/rasp ... dp/2525225 it'll cost about $35
kusti8
Fri Apr 07, 2017 6:28 pm
No. It would cost so much to repair it and you really have to be qualified and have the parts. Plus, they don't sell the chip individually and you can't really solder it to the board. Unless you're looking for something to do for the next year, no.
There are 10 types of people: those who understand binary and those who don't.
btu
Fri Apr 07, 2017 6:29 pm
I will try.
btu
Fri Apr 07, 2017 6:32 pm
kusti8 wrote: No. It would cost so much to repair it and you really have to be qualified and have the parts. Plus, they don't sell the chip individually and you can't really solder it to the board. Unless you're looking for something to do for the next year, no.
Thanks for your suggestion.
