Yours is not to question why, yours is but to do and try as Dougie says. (With apologies to Tennyson!)Gpai wrote:But then shouldn't it just turn off? And I have run it for two days one a one amp adapter, then it worked just fine..
The RPi has circuitry to show undervoltage, it is likely the Power Supply has been working overtime trying to supply adequate voltage and may be failing ??Gpai wrote:But then shouldn't it just turn off? And I have run it for two days one a one amp adapter, then it worked just fine..
Some things may not work and as you try more intensive programs or add things to the USB, it will get unstable and not enough power will be gotten. It doesn't shut off if there isn't enough, it'll just behave erratically.Gpai wrote:But then shouldn't it just turn off? And I have run it for two days one a one amp adapter, then it worked just fine..
