Martyparty
GPS error
Tue Apr 04, 2017 10:07 am
I am working with a GPS NEO 6M, and I finally get data from both the cat /dev/serial0, and the gpsmon /dev/serial0. But when running sudo gpsmon /dev/serial0, it suddenly stops and I get this message: Read error from device. What's the reason for this?
And when trying to run cgps -s, I get no information, and next to status it stands NO FIX (0 sec), what does this mean?
I am also wondering how I can get this information into a live stream of the coordinates?
Thank you for any answers.
topguy
Re: GPS error
Tue Apr 04, 2017 12:15 pm
cgps is a client program for GPSD, is GPSD running ?
gpsmon is a program that reads directly from serialport. You should not run this program at the same time as GPSD, only one program should read from the serialport at any time.
Martyparty
Re: GPS error
Tue Apr 04, 2017 12:22 pm
topguy wrote:cgps is a client program for GPSD, is GPSD running ?
I used this code
sudo systemctl stop gpsd.socket
sudo systemctl disable gpsd.socket
and then
sudo killall gpsd
sudo gpsd /dev/serial0 -F /var/run/gpsd.sock
and then
cgps -s
How do I get the GPSD to run?
Martyparty
Re: GPS error
Tue Apr 04, 2017 12:26 pm
I used this code
and then
sudo killall gpsd
and then
cgps -s
I have also installed the gpsd with this code
sudo apt-get install gpsd gpsd-clients python-gps
Martyparty
Re: GPS error
Tue Apr 04, 2017 12:32 pm
Tried running this code, which is supposed to start gpsd
gpsd -D 5 -N -n /dev/serial0
And got this
gpsd:INFO: launching (Version 3.11)
gpsd:IO: opening IPv4 socket
gpsd:IO: opening IPv6 socket
gpsd:INFO: listening on port gpsd
gpsd:PROG: NTPD shmat(884745,0,0) succeeded, segment 2
gpsd:PROG: NTPD shmat(917514,0,0) succeeded, segment 3
gpsd:PROG: successfully connected to the DBUS system bus
gpsd:PROG: shmat() succeeded, segment 950283
gpsd:PROG: shared-segment creation succeeded,
gpsd:INFO: stashing device /dev/serial0 at slot 0
gpsd:INFO: opening GPS data source type 2 at '/dev/serial0'
gpsd:ERROR: device open failed: Permission denied - retrying read-only
gpsd:ERROR: read-only device open failed: Permission denied
gpsd:ERROR: initial GPS device /dev/serial0 open failed
gpsd:INFO: running with effective group ID 1000
gpsd:INFO: running with effective user ID 1000
gpsd:INFO: startup at 2017-04-04T12:31:00.000Z (1491309060)
topguy
Re: GPS error
Tue Apr 04, 2017 12:39 pm
This is where you turned OFF the GPSD..
So to turn in on again you use the opposite commands ( "enable" and "start" )
But you have to contigure GPSD so it uses correct serialport and baudrate.
Martyparty
Re: GPS error
Fri Apr 21, 2017 10:22 am
Thank you. I got it working the other day, when turning it on, but today it is not working again.. I thought the serialport was supposed to be turned off?
Martyparty
Re: GPS error
Fri Apr 21, 2017 10:24 am
Error when using the code
gpsmon /dev/serial0
I get this message
tcp://localhost:2947:dev/seriaJSON slave driver>
(115) {"class":"VERSION","release":"3.11","rev":"3.11-3","proto_major":3,"proto_
minor":9,"remote":"tcp://localhost:2947"}
(59) {"class":"ERROR","message":"No such device as dev/serial0"}
Martyparty
Re: GPS error
Fri Apr 21, 2017 11:09 am
Now when running gpsmon /dev/serial0
I get this error
gpsmon:ERROR: device open failed: No such file or directory - retrying read-only
gpsmon:ERROR: read-only device open failed: No such file or directory
gpsmon: activation of device /dev/serial0 failed, errno=2 (No such file or directory)
Does anyone know why this happens now?
texy
Re: GPS error
Fri Apr 28, 2017 8:11 am
Martyparty wrote:I am working with a GPS NEO 6M, and I finally get data from both the cat /dev/serial0, and the gpsmon /dev/serial0. But when running sudo gpsmon /dev/serial0, it suddenly stops and I get this message: Read error from device. What's the reason for this?
Are you using a Pi for this? If so, why post in off-topic?
Return to “Off topic discussion”
