vgs1988
pigpio hardware PWM generation
Sun Apr 02, 2017 8:40 am
Hello.
Would you please help me about writing a simple c code to make hardware pwm signal in pigpio library?
joan
Re: pigpio hardware PWM generation
Sun Apr 02, 2017 10:08 am
For hardware PWM see http://abyz.co.uk/rpi/pigpio/cif.html#gpioHardwarePWM
#include <stdio.h>
#include <stdint.h>
#include <pigpio.h>
int main(int argc, char *argv[])
   if (gpioInitialise() < 0) return 1;
   printf("start piscope\n");
   printf("press return to continue\n");
   getchar();
   gpioHardwarePWM(12, 5000, 500000);
   gpioHardwarePWM(13, 10000, 100000);
   printf("STOP piscope\n");
   getchar();
   gpioHardwarePWM(12, 0, 0);
   gpioHardwarePWM(13, 0, 0);
   gpioTerminate();
   return 0;
Ignore the piscope prompts (just press return).
vgs1988
Sun Apr 02, 2017 9:06 pm
Thanks Mr Joan for your help.
I appreciate your nice package.
I put the above code inn a file hardpwm.c and copied it to PIGPIO folder.
when I run the above code using
cc -o hardpwm hardpwm.c
command, I get the following error:
/tmp/ccMqAptM.o: In function `main':
hardpwm.c:(.text+0x14): undefined reference to `gpioInitialise'
hardpwm.c:(.text+0x4c): undefined reference to `gpioHardwarePWM'
hardpwm.c:(.text+0x5c): undefined reference to `gpioHardwarePWM'
hardpwm.c:(.text+0x80): undefined reference to `gpioHardwarePWM'
hardpwm.c:(.text+0x90): undefined reference to `gpioHardwarePWM'
hardpwm.c:(.text+0x94): undefined reference to `gpioTerminate'
collect2: ld returned 1 exit status
Would you please help me about that?
Stiller
Mon Apr 03, 2017 6:20 am
hello,
although I am not familiar with pigpio, and I'm not quite sure about your compiler or linker flags, but did you try and add the flag
-lpigpio
or not? Just a guess, as I said, I am not familiar with pigpio.
vgs1988
Mon Apr 03, 2017 7:59 am
You are right.
The problem was solved by adding proper options.
I use this code for generating software pwm pulse on pin GPIO 24, but it doesnt show anything on oscilloscope:
#include <stdio.h>
#include <stdint.h>
#include <pigpio.h>
gpioSetPWMfrequency(24, 10000);
gpioSetPWMrange(24, 100);
gpioPWM(24, 50);
return 0;
What is wrong with the above code?
Also I am looking for a simple c code for soft pwm generation with arbitrary duty cycle. It seems that pigpio package soft pwm generation macros are defined in a manner that you can choose between a limited number of duty cycles.
Return to “C/C++”
