zjosh15
GPIO pin internet connection
Thu Mar 30, 2017 4:33 am
Does anybody know if a rpi A+ or zero could be connected to an internet network through the GPIO pins. I want to put together a parallel processing cluster using the smaller form factor and without having to get Ethernet cables. Can it be done or am i grasping at straws?
jadro
Re: GPIO pin internet connection
Thu Mar 30, 2017 9:54 am
why do not connect wireless module on it?
Jadro
Oracle backend database developer
SmartHome IoT & Microprocessor enthusiast and hobbyist
faramon
Thu Mar 30, 2017 10:56 am
See this link viewtopic.php?f=63&t=137909
Faramon
Thu Mar 30, 2017 1:22 pm
mfa298
Thu Mar 30, 2017 2:14 pm
zjosh15 wrote:Does anybody know if a rpi A+ or zero could be connected to an internet network through the GPIO pins. I want to put together a parallel processing cluster using the smaller form factor and without having to get Ethernet cables. Can it be done or am i grasping at straws?
For the Zero you could always use gadget mode Ethernet, meaning you get power and Ethernet from the host machine over the same usb connection. I think that's the idea behind the Cluster HAT which uses a Pi2/Pi3 as the cost and 4 Zeros as part of the cluster.
