daszorz
Does the Raspberry Pi Zero W's wifi support monitor mode?
Tue Mar 28, 2017 2:07 pm
I want to do a few security based projects, so my question is "does the Raspberry Pi Zero W's wifi support monitor (promiscuous) mode?"
dukla2000
Re: Does the Raspberry Pi Zero W's wifi support monitor mode
Wed Mar 29, 2017 12:36 am
My Pi3 doesn't so I guess the zero won't either as apparently the same chip.
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
dezaF
Thu Jul 06, 2017 3:02 pm
Yes:
Either get the seemoo labs driver built : https://github.com/seemoo-lab/nexmon
or just download a Kali Nethunter image from https://build.nethunter.com/nexmon-pi-builds/ Rpi3 and Rpi0w images are available.
Regards
Septell
Re: Does the Raspberry Pi Zero W's wifi support monitor mode?
Sat Apr 28, 2018 7:32 pm
I've tried mounting the images at https://build.nethunter.com/nexmon-pi-builds, but they hang. Could it be that my Pi 0 W is a later version than what these were tested on? Mine has the wifi built into the board. Thanks
drgeoff
Sun Apr 29, 2018 12:43 pm
What do you mean by "mounting the images"? What do you mean by "hang" - exactly what happens?
All RPi ZeroWs have Wi-Fi built into the board.
Septell
Sun Apr 29, 2018 3:43 pm
I meant that I had flashed the image onto the sd card in the pi. And by "hang", I meant that that nothing happened after that. It is now working for some reason. Not sure what I did.. The wifi goes into monitor mode etc etc. Thank you anyway, for being kind enough to reply. :)
BharatNT2IE
Sat May 05, 2018 4:26 am
I have a RPI 3B , do i have to install Kali Linux or can i do it from my noobs OS ?
Return to “Advanced users”
