matbos
Quake 3 crash
Thu Sep 20, 2012 1:03 pm
Whet i run ./start.sh i get:
root@raspberrypi:/home/pi/quake3# ./start.sh
ioq3 1.35 linux-arm Apr 28 2012
----- FS_Startup -----
Current search path:
/root/.q3a/baseq3
./baseq3/pak8.pk3 (9 files)
./baseq3/pak7.pk3 (4 files)
./baseq3/pak6.pk3 (64 files)
./baseq3/pak5.pk3 (7 files)
./baseq3/pak4.pk3 (272 files)
./baseq3/pak3.pk3 (4 files)
./baseq3/pak2.pk3 (148 files)
./baseq3/pak1.pk3 (26 files)
./baseq3/pak0.pk3 (1387 files)
./baseq3
1921 files in pk3 files
WARNING: pak0.pk3 is present but its checksum (2985612116)
is not correct. Please re-install the point release
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
WARNING: cvar 'r_znear' out of range (min 0.001000), setting to 0.001000
SDL using driver "x11"
Chose EGL config 22: r=5,g=6,b=5,a=0, depth=24,stencil=0, samples=4,sample_buffers=1
Using native window 0
Window size: 1920x1080
Initializing OpenGL extensions
...GL_EXT_texture_compression_s3tc not found
...GL_S3_s3tc not found
GL_VENDOR: Broadcom
GL_RENDERER: VideoCore IV HW
GL_VERSION: OpenGL ES-CM 1.1
GL_EXTENSIONS: GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_query_matrix GL_OES_framebuffer_object GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_depth32 GL_OES_stencil8 GL_OES_draw_texture GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_OES_matrix_palette GL_EXT_debug_marker
GL_MAX_TEXTURE_SIZE: 2048
GL_MAX_TEXTURE_UNITS_ARB: 0
PIXELFORMAT: color(16-bits) Z(24-bit) stencil(0-bits)
MODE: 3, 1920 x 1080 fullscreen hz:N/A
GAMMA: software w/ 0 overbright bits
rendering primitives: multiple glArrayElement
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 0
multitexture: enabled
compiled vertex arrays: disabled
texenv add: enabled
compressed textures: disabled
2580187472: glGetError 0x500
2580188227: glGetError 0x500
2580188697: glGetError 0x500
2580189429: glGetError 0x500
2580189974: glGetError 0x500
2580190404: glGetError 0x500
2580190842: glGetError 0x500
2580205567: glGetError 0x500
2580206051: glGetError 0x500
2580206485: glGetError 0x500
2580206920: glGetError 0x500
2580207416: glGetError 0x500
2580207865: glGetError 0x500
2580208308: glGetError 0x500
2580208768: glGetError 0x500
2580209294: glGetError 0x500
2580214927: glGetError 0x500
2580215475: glGetError 0x500
2580215886: glGetError 0x500
2580216286: glGetError 0x500
2580216721: glGetError 0x500
2580217167: glGetError 0x500
2580217707: glGetError 0x500
2580218163: glGetError 0x500
2580218622: glGetError 0x500
2580219088: glGetError 0x500
2580219599: glGetError 0x500
2580224895: glGetError 0x500
2580225679: glGetError 0x500
2580226586: glGetError 0x500
2580227245: glGetError 0x500
2580228108: glGetError 0x500
2580231658: glGetError 0x500
2580232331: glGetError 0x500
2580233258: glGetError 0x500
2580234317: glGetError 0x500
2580239986: glGetError 0x500
Initializing Shaders
2580726477: glGetError 0x500
2580732293: glGetError 0x500
2580733095: glGetError 0x500
glGetError() = 0x500
----- finished R_Init -----
2580781554: glGetError 0x500
2580807496: glGetError 0x500
2580837696: glGetError 0x500
------ Initializing Sound ------
----- Sound Info -----
   -1 stereo
    0 samples
    0 samplebits
    0 submission_chunk
    0 speed
(nil) dma buffer
No background file.
Sound initialization successful.
Sound memory manager started
Loading dll file ui.
Sys_LoadDll(/home/pi/quake3/baseq3/uiarm.so)...
Sys_LoadDll(/home/pi/quake3/baseq3/uiarm.so) failed:
"Failed loading /home/pi/quake3/baseq3/uiarm.so: /home/pi/quake3/baseq3/uiarm.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/root/.q3a/baseq3/uiarm.so)...
Sys_LoadDll(/root/.q3a/baseq3/uiarm.so) failed:
"Failed loading /root/.q3a/baseq3/uiarm.so: /root/.q3a/baseq3/uiarm.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(./baseq3/uiarm.so)...
Sys_LoadDll(./baseq3/uiarm.so) failed:
"Failed loading ./baseq3/uiarm.so: ./baseq3/uiarm.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(ui) failed to load library
Failed to load dll, looking for qvm.
Loading vm file vm/ui.qvm...
Architecture doesn't have a bytecode compiler, using interpreter
ui loaded in 2348480 bytes on the hunk
9 arenas parsed
6 bots parsed
2581521421: glGetError 0x500
2581614082: glGetError 0x500
2581666689: glGetError 0x500
2581699333: glGetError 0x500
2581731993: glGetError 0x500
2581766441: glGetError 0x500
2582056482: glGetError 0x500
2582062467: glGetError 0x500
2582120662: glGetError 0x500
2582140549: glGetError 0x500
2582160928: glGetError 0x500
--- Common Initialization Complete ---
IP: 127.0.0.1
IP: 84.41.55.201
Opening IP6 socket: [::]:27960
WARNING: NET_IP6Socket: socket: Address family not supported by protocol
WARNING: Couldn't bind to a v6 ip address.
Opening IP socket: 0.0.0.0:27960
And then it just stops.
malakai
Re: Quake 3 crash
Thu Sep 20, 2012 1:30 pm
What build are you running, wheezy?
Have you tried this article http://mitchtech.net/install-quake-3-on-raspberry-pi/
Possibly try
yum install driconf
Then, as the user who will be running the game, run:
driconf
and under Image Quality, enable S3TC textures. That did it for me.
Return to “Raspberry Pi OS”
