But I'd like to have the fall back from 1Ghz be a bit more than 700MHz - is this easily possible to set?
regards
Simon
Only with force_turbo (and setting the warranty bit)simplesi wrote:The new turbo mode is great for the masses that just want to speed things up but still stay on the right side of the warranty line
regards
Simon
Have you a link to where/how to do that?Only with force_turbo (and setting the warranty bit)
Yes, it pretty much makes overclock behave like it did before the cpufreq driver. Some info here:simplesi wrote:Have you a link to where/how to do that?Only with force_turbo (and setting the warranty bit)
(But it sounds a bit just like the old method of straight overclocking/overvolting rather than setting a fallback/minimum speed)
arm_freq_min=100 (plus other _min parameters) is supported and won't set your warranty bit:Mortimer wrote:I read simplesi's query differently dom, and can't understand why the solution to his query should trigger the warranty bit.
As I understand it, he likes that fact that turbo mode now allows a warranty safe 1GHz boost to performance, but would like the idle speed to be LOWER than 700MHz, presumably to maximise power savings. I believe the same query is being asked on the "Auton, The Autonomous Sail Boat" topic too. Surely an underclock, should under any circumstances result in voiding the warranty?
You need to try it to see what its doingis there any advantage to setting a higher idle clock speed, especially for something like Scratch which is almost certainly going to trigger the turbo mode anyway by all accounts?
No, _min values above stock are currently not allowed. I'm considering allowing non-overvolted minimum settings.simplesi wrote:Anyway - are we saying I can set arm_freq_min=800 and the RPi will recognise this (at school a ce moment so can't test)
Thank youI'm considering allowing non-overvolted minimum settings.
Good idea dom. Right now my overclocking settings (which shouldn’t void warranty) are:dom wrote:No, _min values above stock are currently not allowed. I'm considering allowing non-overvolted minimum settings.simplesi wrote:Anyway - are we saying I can set arm_freq_min=800 and the RPi will recognise this (at school a ce moment so can't test)
I was wondering whether this is now possible? e.g. 800mhz as minimum with on demand step up to 1ghzdom wrote:No, _min values above stock are currently not allowed. I'm considering allowing non-overvolted minimum settings.simplesi wrote:Anyway - are we saying I can set arm_freq_min=800 and the RPi will recognise this (at school a ce moment so can't test)
