question to kelster101757: did you find out if node-red uses the RTIMULib.ini file ?
other question: i expect it to be the Hz that should be changed ti increase the readings to 100 pr. sec.
I am not at all into electronics, so:
- how can it be that it is different for all movement-sensors?
- And what should be the new values
