PI_newbee
For MrEngman --> tp-link WN821N driver
Fri Mar 24, 2017 9:17 am
Hi !
I have followed one of yours posts on how to install wifi adapter.
Can you please check the download link on dropbox because i can not download any of the files listed in your posts.
I always get message that the file is missing..
Best regards !
PIN
MrEngman
Re: For MrEngman --> tp-link WN821N driver
Fri Mar 24, 2017 10:47 am
PI_newbee wrote:Hi !
Best regards !
PIN
The drivers I compile were installed on Dropbox but they have made a major change to their web site and its really screwed things up. Really annoying to say the least so I have moved the drivers to a new site. You will need to download and install a new script to use the new site.
Download and install the new version of the script with commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The command
sudo install-wifi -h
will show details on using it.
To install the driver on your current kernel you should just need to run command
sudo install-wifi
This will select the driver you need and automatically download and install it.
MrEngman
PI_newbee
Thu Mar 30, 2017 6:03 pm
I got tears in my eyes :-). I followed your instructions and it just worked ! Great job !
Tell me, do you know how can i connect automatically (after reboot) to my wifi network ?
PIN
Thu Mar 30, 2017 6:16 pm
PI_newbee wrote:I got tears in my eyes :-). I followed your instructions and it just worked ! Great job !
PIN
Once you get WiFi working, reconnect after reboot should happen automagically, as long as your AP is within range of your Raspberry.
This is a doctor free zone.
PI_newbee
Mon Apr 03, 2017 9:58 am
I was bit out of wifi range. My bad.
Everything is working perfect !
