wbickle
Chromium Auto Refresh
Wed Mar 22, 2017 2:59 pm
Running the current version of Pixel on my Pi 3, is it possible to add something to the crontab file which will auto refresh the open Chromium page on a scheduled basis?
TIA.
Bill
dom
Re: Chromium Auto Refresh
Wed Mar 22, 2017 3:30 pm
There are chrome addons that can do this. Does this work?
https://chrome.google.com/webstore/deta ... njkc?hl=en
wbickle
Sat Mar 25, 2017 2:38 pm
Yes! Thanks so much.
Bill
relayman357
Mon Nov 06, 2017 3:30 pm
You may want to check this out before using that extension: https://www.youtube.com/watch?v=9k0wqHMOyD0
This suggests rather convincingly that it is malware.
relayman357
Mon Nov 06, 2017 3:39 pm
Also, if you just need to refresh a local html file then just embed the following meta line in your html file:
<META HTTP-EQUIV="refresh" CONTENT="30"> <! -- This is to force refresh of this page every 30 seconds>
Leon71
Sun Nov 26, 2017 3:11 pm
I have solved it with xdotools
I copied the autostart file from /etc/xdg/lxsession/LXDE-pi/autostart to /home/pi/.config/lxsession/LXDE-pi/autostart with the command:
cp /etc/xdg/lxsession/LXDE-pi/autostart /home/pi/.config/lxsession/LXDE-pi/autostart
After that, I edited the local version:
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart :
@xscreensaver -no-splash
@xset s off
@xset -dpms
@xset s noblank
@chromium-browser --incognito --kiosk http://www.yoursite.com # load chromium after boot
Next, create a file called 'autorefresh-chromium.sh' in /home/pi/ #or any folder you like
chmod the file with the command: chmod 755 /home/pi/autorefresh-chromium.sh to make it exetcutable
Open /home/pi/autorefresh-chromium.sh
Add the following lines:
#!/bin/bash
while true; #create an infinite loop
do
sleep 1200 #refresh time in seconds so 1200 = every 20 min
xdotools key = ”ctrl+F5” & #you need to have xdotools installed
done
Add @/home/pi/autorefresh-chromium.sh to /home/pi/.config/lxsession/LXDE-pi/autostart.
So the file looks like this:
@xset s off
@xset -dpms
@xset s noblank
This worked for me
MWZotti
Wed Mar 28, 2018 1:57 am
Leon71 wrote: I have solved it with xdotools
@xset s off
@xset -dpms
@xset s noblank
#!/bin/bash
do
done
@xset s off
@xset -dpms
@xset s noblank
This worked for me
I copied these directions then wondered why this didn't work. So just to clarify for all others that may want to use this..... you need xdotool and change the line to:
export XAUTHORITY=/home/pi/.Xauthority; export DISPLAY=:0; xdotool key "your key combination here" &
The latest key combos according to google support https://support.google.com/chrome/answer/157179?hl=en :
Reload current page: F5 or Ctrl+r
Reload the current page, ignoring cached content: Shift+F5 or Ctrl+Shift+r
Gerrelt
Tue Apr 10, 2018 6:47 pm
I didn't get this working either, even with the tip from MWZotti. But he did point me in the right direction for the solution, thank you MWZotti!
The problem is that xdotools doesn't work under the root user without setting Xauthority.
And adding it to LXDE autostart will make it run under root.
I solved it by creating another script that will set Xauthority for the root user. This script has to be executed before the autorefresh script.
Instructions:
Install xdotools:
sudo apt-get install xdotool
Next create a script called "xauth_root.sh":
cd /home/pi
sudo nano xauth_root.sh
Then add these lines to it:
#!/bin/bash
# source: https://raspberrypi.stackexchange.com/questions/1719/x11-connection-rejected-because-of-wrong-authentication
touch /root/.Xauthority
xauth merge /home/pi/.Xauthority
export XAUTHORITY=/root/.Xauthority
Make it executable:
sudo chmod 755 xauth_root.sh
Now create this auto refresh script:
sudo nano autorefresh-chromium.sh
Add these lines:
#!/bin/bash
# also see instructions here: https://www.raspberrypi.org/forums/viewtopic.php?t=178206#p1239241
# To make this run with sudo (which is the case when run at boot), execute "xauth_root.sh" before running this script.
# xdotools setup instructions found here: http://theembeddedlab.com/tutorials/simulate-keyboard-mouse-events-xdotool-raspberry-pi/
# This will only set up the DISPLAY variable for one command
DISPLAY=:0 xdotool key "ctrl+F5"
# This will set up the DISPLAY variable for every command executed on this terminal,
# and child processes spawned from this terminal
export DISPLAY=:0
do
  xdotool key "ctrl+F5" &
  sleep 300 #refresh time in seconds so 300 = every 5 min
done
(note that this will refresh it every 5 minutes)
Make it executable:
sudo chmod 755 autorefresh-chromium.sh
Open the LXDE autostart file:
And add these three lines to the end (set the desired URL in the first line):
@chromium-browser --incognito --kiosk http://someURL.youwanttodisplay.com # load chromium after boot
@/home/pi/xauth_root.sh
This worked for me!
(see urls in scripts for sources)
my Raspberry Pi page: http://raspberry.gerrelt.nl
PaoloM
Thu Jun 13, 2019 12:32 pm
Hi guys, is it possible to set only 1 refresh of chromium only at startup?
k0kster
Mon Sep 09, 2019 2:39 am
<META HTTP-EQUIV="refresh" CONTENT="10"> <! -- This is to force refresh of this page every 30 seconds>
hi!
i tried adding the above line into the html file by opening it with chrome and pressing f12.
my head looks like this
https://drive.google.com/open?id=1spQ5B ... HPZMQMpDAA
however, 10 seconds later the meta line diasppears after being refreshed.
theWoosh
Wed Dec 04, 2019 10:40 am
Hi Folks
Just wondering - rather than make a shell script that is always operating in a loop, why not just add a cron job that executes at regular intervals and calls a simple shell script?
SerGiggity
Sat Sep 12, 2020 11:44 am
Apologies but I'm a total newbie at this- how would I use this command to refresh a chromium browser displaying google calendar pls??
stanwin00
Thu Dec 17, 2020 8:44 am
Very good article! thank you!
deepo
Thu Dec 17, 2020 9:23 am
You can't but if you wrote your own html code that would do the trick.
Don't the Google Calendar update the page automatically when something new happens? I would have thought that.
YoctoYotta
Wed Mar 10, 2021 8:05 pm
A word of warning for the few people that might be in the same boat as me. If your web page is prone to time out after an extended time (mine are local-IIS hosted ASP pages for SQL SSRS charts being displayed 24/7), this refresh code can no longer load and the page stops refreshing automatically. In my case, a refresh of the browser page through some other means like a browser plugin or chron script is mandatory.
Also, if anyone has any tips for preventing IIS-hosted ASP pages displaying SQL SSRS charts 24/7 from timing out, please share =)
COASTER19
Fri Mar 19, 2021 2:51 am
THANK YOU! This has issue has been plaguing my information kiosk for ages.
To avoid all of the root issues just add the following to crontab (run crontab -e, NOT sudo crontab -e)
 * * * * * DISPLAY=:0 /home/pi/crontabrefresh.sh
and create the file crontabrefresh.sh in your home folder with the following content:
#!/bin/bash
xdotool key shift+F5
and make it executable with
chmod 755 /home/pi/crontabrefresh.sh
Rebooting every night was good enough 90% of the time but sometimes it crashed in the last 4 hours of the day. I assumed it was a memory management or poor programming on my part since I'm using a pi zero, but turns out it was chromium all along (and I know chromium isn't ideal on a pi zero, but midori and kweb have poor CSS support, and firefox doesn't support the older architecture).
