samuel_john64
AttributeError: 'module' object has no attribute 'HTTPconnec
Wed Mar 22, 2017 8:15 am
I'm getting error
File "SaveData6.py", line 48, in <module>
conn = httplib.HTTPconnection("api.thingspeak.com:80")
AttributeError: 'module' object has no attribute 'HTTPconnection'
how to solve this error?
import spidev
import datetime
import RPi.GPIO as GPIO
from time import sleep
import httplib, urllib, time
GPIO.setmode(GPIO.BOARD)
# Open up SPI bus
spi = spidev.SpiDev()
spi.open(0,1)
# Initialize Sensor
SoilSensor = 5
Pump = 22
sleepTime = 1
# Setup the pin that pump connected to
GPIO.setup(Pump, GPIO.OUT)
#Declare API Key
apikey = 'xxx'
def getReading(channel):
	# Get Raw Data from chip
	rawData = spi.xfer([1, (8 + channel) << 4, 0])
	# Process Data to Understandable
	processedData = ((rawData[1]&3) <<8) + rawData[2]
	return processedData
def convertVoltage(bitValue, decimalPlaces=2):
	voltage = (bitValue * 3.3) / float(1023)
	voltage = round(voltage, decimalPlaces)
	return voltage
try:
  while True:
      delta = datetime.timedelta(minutes=1)
      next_time = datetime.datetime.now() + delta
      SoilData = getReading(SoilSensor)
      SoilVoltage = convertVoltage(SoilData)
      params = urllib.urlencode({'field': SoilData, 'key': apikey})
      headers = {"Contect-type": "application/x-www-form-urlencode","Accept": "text/plain"}
      while True:
          #Print Values
          print("Soil Moisture bitValue = {} ; Voltage = {} V".format(SoilData, SoilVoltage))
          sleep(sleepTime)
          dt = datetime.datetime.now()
          #Save Result Every One Hour
          if dt > next_time:
	          print("---------------  write file -----------------------")
	          file = open("/home/pi/Desktop/result/result.txt", "a")
	          file.write("{} ; Soil Moisture bitValue = {} ; Voltage = {} V\n".format(dt.strftime("%d-%m-%Y %H:%M:%S"),SoilData, SoilVoltage))
	          file.close()
	          next_time = dt + delta
		  conn.request("POST", "/update", params, headers)
		  response = conn.getresponse()
		  print response.status, response.reason
		  data = response.read()
		  conn.close()
	  if SoilData < 40:
		GPIO.output (Pump, True)
	  else:
		GPIO.output (Pump, False)
finally:
	# Reset the GPIO Pins to a safe state
	GPIO.cleanup()
ktb
Re: AttributeError: 'module' object has no attribute 'HTTPco
Wed Mar 22, 2017 8:47 am
HTTPConnection, not HTTPconnection
samuel_john64
Wed Mar 22, 2017 10:32 am
ktb wrote:HTTPConnection, not HTTPconnection
thanks for ur kind help.
Return to “Python”
