sispheor
Kalliope (Jarvis like assistant)
Tue Mar 21, 2017 2:04 pm
Hi!
We made a little bot assistant for the Rpi !
It's more like a framework where you you can build your own assistant like Jarvis in the language of your choice.
Some modules (neurons) are already availlable to make your brain(eg: gmail, gcalendar, facebook, date,...).
And you are free to create your own and propose them to the community.
Demo video
The website
The source code
Already available modules
YCN-
Re: Kalliope (Jarvis like assistant)
Tue Mar 21, 2017 3:33 pm
Wonderfull I like this kind of project !
What did you use for voice recognition ?
I like the way you did the "synapses" stuff. I'm not really sure that I exactly get what you meant. Is it like plug-in ?
Is one built for the use of relays ?
YCN-
sispheor
Tue Mar 21, 2017 4:19 pm
For the voice recognition you can select a STT engine. There is also a self hosted one.
Yes a synapse is the link between input and output actions.
The input is your order, the output is a neuron (a plugin).
There is no neuron for controling GPIO direclty. But you can use the neuron script
or shellto do it.
bacardi55
Tue Mar 21, 2017 4:41 pm
Multiple STT and TSS can be setup (with multiple languages), I'm mainly using google STT for now as on a single RPI, it can become a bit slow to install too much stuff on it (already have Kalliopé and Mopidy) ^^.
Sispheor has explained the synapses, but the idea is really simple:
Links your voice orders (input) and neurons (functionality and message templates - the output).
So you can create orders and templates in the language you need and just reuse data sent back by the neurons. Readme of neurons can give you more ideas of what I mean :).
For the GPIO connection or other domotic devices, I'm using domoticz to manage them, and created a neuron for Kalliopé to interact with domoticz.
If you are interested, I wrote some stuff about my (heavy?) kalliopé usage here
That being said, Kalliopé is a cool tool and have now some cool neurons
YCN-
Wed Mar 22, 2017 9:28 am
Wow !
I love it !! I was thinking about doing this kind of assistant myself, but I would have done it with a low level approach, using C and my I/O would have been very user-specific, but I like your style, it's better and more user-friendly.
I think that I'll soon get involved in the project, did you consider adding an http server so that you can drive kalliope in a silent mode? May be with a web site for the user where you'll only see something as the facebook messenger app. I'm not really into web devellopment but that could be something I'd like to have.
What do you think ? What's your current approach for voice recognition ? Do you translate words into strings and then annalyse them ? If this is how you do it, the server might be pretty straight forward, I'll just have to forward to kalliope the http string data.
YCN-
sispheor
Wed Mar 22, 2017 9:37 am
Currently Kalliope has an API.
A projecthas been started for controlling Kalliope via web interface.
And a Phone app should be available soon.
And yes we convert voice into string and then we analyse them to match a declared order in the conf.
bacardi55
Wed Mar 22, 2017 9:41 am
YCN- wrote:Wow !
I'm not sure what you mean by "silent mode" ^^.
Kalliopé provide an API so you can start synapse (or order) via API. You can even send an audio file via API and then Kalliopé will use the TTS as usual.
That being said, when you use the API, the synapse is executed on the rpi, so if your synapse has an audio return, it will be said on the rpi that leverage kalliopé. I have created an issue to maybe modify this behavior, but it's not started yet. Issue can be found here
Also, I have started a web remote app (using emberjs) that leverage the API to run synapse. I have stopped for some time to contribute to more neurons but I'll restart working on it soon. It will be able to send free text (orders) or an audio file, so you won't need a mic or being in the same room as your Kalliopé
App can be found here
YCN- wrote: What do you think ? What's your current approach for voice recognition ? Do you translate words into strings and then annalyse them ? If this is how you do it, the server might be pretty straight forward, I'll just have to forward to kalliope the http string data.
YCN-
Yes, Voice recognition works by transforming audio into strings that are then analyse by kalliopé.
YCN-
Wed Mar 22, 2017 9:57 am
Well I was meaning instead of talking to kalliope finding a way to write to kalliope. For instance with a chat interface such as the messenger app. I don't really like the idea of talking to a robot. That why I'd like to have a web interface where I would be able to write what I would have said.
You'll go to a web page and then just write and have responce in real time with kalliope. Just like the FaceBook messenger app or whatever messenger you use (whatsapp...).
I'll give it a try soon I don't think it will be too complicated.
YCN-
bacardi55
Wed Mar 22, 2017 10:00 am
YCN- wrote:Well I was meaning instead of talking to kalliope finding a way to write to kalliope. For instance with a chat interface such as the messenger app. I don't really like the idea of talking to a robot. That why I'd like to have a web interface where I would be able to write what I would have said.
YCN-
That is the goal of the web app i've done. So far, it's only listing available synapse and you can click to start them. I had in mind this ability to just run free text so it's in the roadmap, just had no time to tackle it yet.
Otherwise, I started a small CLI tool to do so, where you have a prompt and can simply type "order my great order" and it will send the order via API ("my great order"). You can find it here but it is just started (but this feature works).
I had in mind other features like installing new neurons or even configuring kalliopé via this tool.
*edit* : the link is: https://github.com/bacardi55/kalliope-cli
But all this is still yound and need more work :)
morecoffee
Sun Apr 02, 2017 2:50 am
bacardi5,
I'm trying to run you CLI interface on a raspberry pi B to get an idea of how things works. I am using the v0.4.3 image. I'm having some trouble getting started. All I have done is setup the image and download your CLI program and changed it to executable.
When I run the command
kalliope start
I get a long message that ends with:
in swig_import_helper
import _snowboydetect
ImportError: No module named _snowboydetect
When I try
./kalliope-cli.py
The results were:
File "./kalliope-cli.py", line 10, in <module>
from cmd2 import Cmd
ImportError: No module named cmd2
sispheor
Thu Apr 06, 2017 9:16 am
Is that ok for you now @morecoffee?
morecoffee
Thu Apr 06, 2017 1:43 pm
I'm fine for now. I plan on getting a Pi 3B with a mic and try again later. Thanks for the help on the gitter chat. I look forward seeing how this project continues to develop.
sispheor
Wed Jun 28, 2017 10:00 am
Version 0.4.4 online! https://github.com/kalliope-project/kal ... tag/v0.4.4
Better performance on Rpi !
sispheor
Sun Jan 14, 2018 10:11 pm
V0.5.0 online !!
New text to speech, hooks support and more. See the complete changelog here.
sispheor
Thu May 31, 2018 2:03 pm
v0.5.1 online.
You can now chain your orders!
New doc: https://kalliope-project.github.io/kalliope/
NOsen
Sun Jul 15, 2018 6:49 pm
First of all thank you for your work on this.
Question i got it running on my raspberry it talks i can chat with it from my phone
however when i use the hotword "snowboy" it do not respond at all im using google speech to text paid version with a proper API key
If i record from the mic it works and it sounds good when i play up it but it just wont respond to any spoken word.
my asoundrc looks like this
 cat .asoundrc
pcm.!default {
    type hw
    card 1
ctl.!default {
    type hw
    card 1
and like i wrote it do record my voice when i run arecord.
My settings file
default_speech_to_text: "google"
speech_to_text:
  - google:
      language: "en-EN"
      key: "APICODE"
it seems like its not even trying to connect to google at all my google account has 0 hits and im running the API unrestricted so it should work
Kalliope log (there is no errors in the eror log
Starting REST API Listening port: 5000
Starting Kalliope
Press Ctrl+C for stopping
zy loading)
Starting order signal
 * Environment: production
I'm ready
   WARNING: Do not use the development server in a production environment.
   Use a production WSGI server instead.
 * Debug mode: on
Any suggestions would be appreciated!
Mistgun
Mon Jun 03, 2019 7:44 am
Salut,
J'ai actuellement installé Kalliope et Matrix voice sur ma Raspberry.
-J'ai créer un mini programme lumière avec Matrix qui se trouve: cd /root/matrix-hal-project/matrix-hal-project/app
"app" étant compilé, est exécutable avec la commande ./app
-J'ai modif mon brain.yml pour créer une nouvelle commande:
- name: "lumieretest"
signals:
- order: "lumieretest"
neurons:
- shell:
cmd: "cd /root/matrix-hal-project/matrix-hal-project/app"
- say:
message: "lumiere active"
Problème: Il n'exécute pas "app", comment je dois faire pour qu'il l'exécute (./app) ?
(sachant que "app" est en C++ et a été compilé avec g++)
sispheor
Sun Jun 16, 2019 8:48 pm
c'st pas cmd: "cd /root/matrix-hal-project/matrix-hal-project/app"
mais
cmd: "cd /root/matrix-hal-project/matrix-hal-project/ && ./app"
je pense
Mistgun
Tue Jun 18, 2019 7:09 am
Salut,
Oui effectivement c'est sa, j'avais trouvé mais je n'avais pas publié la réponse ici.
J'ai une 2ème question: J'ai fait un script bash/shell (api.sh) qui en gros récupère des valeurs sur un site puis les affiches (via "echo") et j'aimerai savoir comment faire pour que Kalliope puisse lire ces valeurs
EDIT:
J'ai fait une fonction à l'intérieur de mon shell (api.sh) et prenons comme exemple $valeur = 1 :
function apitest {
code
apitest() {
echo "valeur: "$valeur
apitest
Le problème est que quand le fichier est exécuté par Kalliope: Tout s'affiche correctement sauf la valeur de "$valeur"
Il me met:
valeur:
à la place de:
valeur: 1
Que faire ?
Merci (et oui je suis sans doute pas sur le bon forum pour cette question ;) )
salomeleduc
Wed Jul 17, 2019 2:34 pm
Hello everyone, I know those post are old but I'm trying Kalliope and I have an issue : I'm using the Kalliope_starter_fr and pronounce "Kalliope" but nothing happened.
My microphone is working and when I was working with CMU Sphinx it was listening to me, but here, I have nothing.
Could you help me?
Thanks !!
Salomé
evansusu
Fri Jul 26, 2019 7:00 am
EditDelete postReport this postQuote
Fri Jul 26, 2019 3:00 pm
https://www.thegeekpub.com/16187/contro ... pberry-pi/
Hi Guys, I followed this tutorial to light up a WS2812b led strip with 60 LEDS using a raspberry pi. Unfortunately it doesn't work.
'import board
import neopixel
pixels = neopixel.NeoPixel(board.D18, 60)
pixels[0] = (255, 0, 0)
After running it, I got this error in the images
