poseidon
Gertbot on a RPi3 - Need help accessing GPIOs
Sun Mar 19, 2017 12:30 pm
Dear Raspians,
I'd like to drive some LEDs using J3 on my Gertbot stacked onto a Raspberry Pi 3 until I get at some motors to drive them via the Gertbot.
How would I do that?
The manual seems to have some weak spots, e.g. I couldn't find J3 explained: Where is GND? Where is pin 1? How much current will be supplied? Is it 5V (I own some LEDs w/ a built-in resistor, i.e. they can be directly connected to a 5V-source)? Some pictures would be helpful. The picture on page 19 of the manual "Gertbot, Rev 2.5/2.6, 26 April 2015" is a good start.
Some Python code in the manual would be helpful too. After digging through the "Gertbot Debug and Development GUI" sources I eventually found test_drivers.zip on this forum. Alas, calling test_drives -t11 -b0 doesnt' light my LED. I guess, this is because I connected it the wrong way.
So has anyone a description of the J3 pins?
Kind regards
Paul
Gert van Loo
Re: Gertbot on a RPi3 - Need help accessing GPIOs
Sun Mar 19, 2017 6:21 pm
Paul,
first: if you post questions about the gertbot in the 'gert board classic' section I get to see them sooner
as I get an email for posts in there.
As to the J3: yes it is an omission in the main manual. I am working on an updated version.
Below is a picture to get you started. A bit more about the pins can be found in the Gert bot Gui manual. From page 10 onwards is a section about the J3 connector. https://www.gertbot.com/gbdownload/man/Gertbot_GUI.pdf
If you don't have motors you can connect LEDs to the motor pins. As the minimum operating voltage is 8V the series resistor needs to be a bit bigger then for 3V3 or 5V. 4700 ohms should do. If you connect a RED and a GREEN LED back-to back you can even see the
direction "the motor" is turning. I have quickly drawn a picture using Paint:
Full drivers, source code, examples and test code can be found on the gertbot website: http://www.gertbot.com.
See https://www.gertbot.com/download.html
Especially to sort out your connections I recommended you use the Gert-bot GUI as first tool.
When you got things working with that, then it is time to start playing with your own code, drivers etc.
Return to “Beginners”
