dorijan
Whats wrong with my date
Wed Sep 19, 2012 1:21 am
Hi to all..
I thought Raspbian is using NTP to sync my clock. But this is not happening...
pi@raspberrypi ~ $ date
Pet Kol 24 12:31:46 CEST 2012
(it is 24.8.2012)
my timezone is right
pi@raspberrypi ~ $ cat /etc/timezone
Europe/Zagreb
I also have internet access
pi@raspberrypi ~ $ ping http://www.google.com
PING http://www.google.com (208.117.229.183) 56(84) bytes of data.
64 bytes from cache.google.com (208.117.229.183): icmp_req=1 ttl=48 time=5.81 ms
Also:
pi@raspberrypi ~ $ ntpq -p
remote refid st t when poll reach delay offset jitter
161.53.160.4 .INIT. 16 u - 512 0 0.000 0.000 0.000
Does anyone know what is wrong?
Thank you
joan
Re: Whats wrong with my date
Wed Sep 19, 2012 7:28 am
It's a service I use without wondering how it works.
However shouldn't you have more than one clock source?
joan@mercury:~$ ntpq -p
+trust.nobody.at 193.171.23.163   2 u    1   64  377   41.469   -5.896   1.440
+ntp1.karneval.c 195.113.144.201  2 u   60   64  377   37.085   -5.778   0.804
-intserv-new.net 130.149.17.21    2 u   56   64  377   38.190   -5.458   0.835
*panoramix.linoc 193.67.79.202    2 u   61   64  377   28.055   -6.010   0.731
Perhaps you could manually set some clock sources?
morgad
Wed Sep 19, 2012 7:46 pm
Try commenting out the 'server' line in your /etc/ntp.conf and replacing it with -
pool pool.ntp.org iburst preempt
(you might need a
tos minclock 3 maxclock 4
as well)
This will automatically replace unreachable clock sources with new ones from the pool.
The pool command is a new feature of recent ntp versions.
If that does not work please post your full ntp.conf file in case there is a problem somewhere else.
best regards
Dave
alfonso82
Thu Nov 22, 2012 12:36 am
Hello I just got my pi a few weeks ago and I´m having the same problems with my NTP configuracion, did you found a solution for this issue dorijan? or is anyone out there that knows whats is wrong?
plugwash
Fri Nov 23, 2012 4:17 am
do you have -g specified in /etc/default/ntp ?
alfonso82
Sun Nov 25, 2012 2:42 am
Hi plugwash and thank you for replying, and the answer to your question is yes, this is what it shows in the /etc/default/ntp file.
NTPD_OPTS='-g'
and that is it.
Return to “Raspberry Pi OS”
