samuel_john64
sleekxmpp.xmlstream could not Connect Error
Wed Mar 15, 2017 10:28 am
im Receiving the error when i try to run my coding.what should i do to solve this error?
ERROR:sleekxmpp.xmlstream.xmlstream:Could not connect to 104.198.88.230:5222. Socket Error #110: Connection timed out
Coding
from time import sleep
import mcp3008
from controlmypi import ControlMyPi
import logging
def on_msg(conn, key, value):
pass
logging.basicConfig(level=logging.INFO)
p = [
[ ['G','moist','level',0,0,1023] ],
conn = ControlMyPi('soilmoisturemonitoring@xmpp.jp', 'soilmoisturemonitoring123', 'moisture', 'Moisture monitor', p, on_msg)
if conn.start_control():
try:
while True:
m = mcp3008.readadc(5)
conn.update_status({'moist':m})
sleep(30)
finally:
conn.stop_control()
Re: sleekxmpp.xmlstream could not Connect Error
Wed Mar 15, 2017 10:33 am
Who owns that server at: 104.198.88.230 (which shows as an address somewhere in San Jose, CA, USA)? The server either isn't open to the public internet or doesn't have the right services running.
samuel_john64
Wed Mar 15, 2017 4:09 pm
not sure the owner of the server seems i got the source code from online and i think the server links to this webside http://www.controlmypi.com/
Wed Mar 15, 2017 5:25 pm
OK, that makes sense. The server wasn't running when your system tried to connect to it. That's probably a transient error.
Return to “Python”
