klintkrossa
Find out if there is broken or missed matched imports
Tue Mar 14, 2017 8:42 pm
Hello
I would like to batch check my imports to find out if there is broken or missed matched imports.
the "import ("%s" % X)" did not work.
PIP_adds is a list of 25 imports that I would like to know if they are there and if not run my def.
What is the magic code for the 4th line down?
try:
    for X in PIP_adds:
        try:
            import ("%s" % X)
        except ImportError:
            print(X + '  Did not import')
            """ dif to load file goes here """
except KeyboardInterrupt:
    pass
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
ghp
Re: Find out if there is broken or missed matched imports
Tue Mar 14, 2017 11:03 pm
I looked around for 'python dynamic module import' and found some solutions. My preferred one is
ilist = [ 'time', 'sys']
for i in ilist:
    s = "import {module:s}\n".format( module = i)
    exec  s
print( time.time() )
print( sys.version_info.major )
Regards,
Gerhard
Paeryn
Tue Mar 14, 2017 11:40 pm
You can use importlib,
import importlib
PIP_adds = ["sys", "time", "gtfre"]
for module in PIP_adds:
  try:
    print("Importing " + module)
    globals()[module] = importlib.import_module(module)
    importlib.invalidate_caches()
  except ImportError:
    print(module + " did not import")
# Show we correctly imported time
print(time.asctime())
pi@rpi3:~/Programming/pyth $ python3 imp.py
Importing sys
Importing time
Importing gtfre
gtfre did not import
Tue Mar 14 23:43:33 2017
She who travels light — forgot something.
klintkrossa
Tue Mar 14, 2017 11:48 pm
Hello all,
Just got back to the Forum.
I guess that asking the question some time triggers a better search.
I looked for a couple hours and found nothing. Ask the question in the Forum then back to google and found this.
__import__()
PIPS = []
try:
    for X in PIP_adds:
        print("\n")
        XL = X.lower()
        XT = X.title()
        try:
            #import ("%s" % X)
           __import__(X)
        except ImportError:
            print(X + "  Did not work")
            try:
               __import__(XL)
            except ImportError:
                print(XL + "  Did not work")
                try:
                    __import__(XT)
                except ImportError:
                    PIPS.append(X)
                    print(XT + "  Did not work")
    print('\n\n')
    for y in PIPS:
        print(y)
    pass
thanks ghp
thanks all
Paeryn
Wed Mar 15, 2017 12:15 am
klintkrossa wrote:Hello all,
__import__()
PIPS = []
try:
    for X in PIP_adds:
        print("\n")
        XL = X.lower()
        XT = X.title()
        try:
            #import ("%s" % X)
           __import__(X)
        except ImportError:
            try:
               __import__(XL)
            except ImportError:
                try:
                    __import__(XT)
                except ImportError:
                    PIPS.append(X)
    print('\n\n')
    for y in PIPS:
        print(y)
    pass
thanks ghp
thanks all
You need to bind the return value to an object else you can't use the imported module/package as you'll have no name to access it by (that's why I entered it into the globals() dictionary in my example). Just noticed I forgot a line in my example (the invalidate_caches() call).
importlib.import_module() is recommended over __import__() unless there is a compelling reason not to.
klintkrossa
Wed Mar 15, 2017 2:05 pm
The import is to see what is missing, broken or needs some more research. For this application and the amount of imports it works fine.
I will keep that in mind for when I have to batch load a lot of files. I know it coming. :D :D
__import__()
PIPS = []
try:
    for X in PIP_adds:
        print("\n")
        XL = X.lower()
        XT = X.title()
        try:
            #import ("%s" % X)
           __import__(X)
        except ImportError:
            try:
               __import__(XL)
            except ImportError:
                try:
                    __import__(XT)
                except ImportError:
                    PIPS.append(X)
    print('\n\n')
    for y in PIPS:
        print(y)
    pass
thanks ghp
thanks all
Klint
Return to “Python”
