recently I've been trying to get my adafruit 2.8 inch touchscreen to work with Kali Linux 2.1.2 for the raspberry pi 2.
Unfortunately i ran into a confusing couple of errors,
the Pi boots normally and the screen runs through several lines of start up commands but stops at emergency mode.
Personally i don't know why this is as it only started after two boots of the pi normally (with the adafruit kernel installed).
However to run in default mode it says to type Control D.
Afterwards it runs through more setup until it stops at an error with the line:
failed to start ... root device.
see 'systemctl stat...ice' for more detail.Code: Select all
Kali GNU/Linux Rolling kali ttylCode: Select all
startxCode: Select all
mktemp: failed to create file via template '/tmp/serverauth.XXXXXXXXXX' : Read-only file systemCode: Select all
xauth: error in locking authority fileCode: Select all
xauth: timeout in locking authority file /root/.authority Code: Select all
Startxfce4Code: Select all
/tmp/.tX0-lockhttp://www.linuxquestions.org/questions ... 175495810/
Again this is on kali linux any help would be well recieved.
Sincerely Koronter
