TonyHoldroyd
Power supply for WD PiDrives (Foundation)
Tue Mar 07, 2017 4:58 pm
Would someone please let me know if the WD PiDrive Foundation edition (375 Gig) requires a separate power supply and if so what I should buy. Thank you.
Re: Power supply for WD PiDrives (Foundation)
Tue Mar 07, 2017 5:14 pm
TonyHoldroyd wrote:Would someone please let me know if the WD PiDrive Foundation edition (375 Gig) requires a separate power supply and if so what I should buy. Thank you.
https://www.wdc.com/en-ie/products/wdla ... ition.html
The info is in the HDD setup PDF
RPi 4B 4GB (SSD Boot)..
Ernst
Tue Mar 07, 2017 5:16 pm
It depends on your Pi, the powersupply and the cable, in general the answer is that you do not need a separate power supply for the PiDrive.
The standard 5.1V 2.5A power supply, with / without the WD cable, on a Pi 3 will work without a problem. The WD power supply with the WD cable may give power low power warning but still works ok.
Tue Mar 07, 2017 5:36 pm
Yes. Buy the WD 5V 3A supply with the appropriate adapter for your local electrical standard sockets.
TonyHoldroyd
Tue Mar 07, 2017 7:42 pm
Ernst wrote:It depends on your Pi, the powersupply and the cable, in general the answer is that you do not need a separate power supply for the PiDrive.
Okay, thanks for that. I'm new to the Pi (3B) and to the forum and appreciate your rapid response.
alphanumeric
Thu Mar 09, 2017 1:30 pm
I'm with Dougie, buy the WD 3A power pack kit with the Pi Drive cable. Then you can run them both from the one Power Pack with no worries.
TonyHoldroyd
Thu Mar 09, 2017 1:40 pm
alphanumeric wrote:I'm with Dougie, buy the WD 3A power pack kit with the Pi Drive cable. Then you can run them both from the one Power Pack with no worries.
OKay, thank you for the advice
