vanteuton
Remote windows 10 from a pi
Tue Mar 07, 2017 10:26 am
I'm setting up a remote raspberry pi to manage my flat, including my main computer
using windows 10.
I already know how to shutdown the main computer from the pi using rpc shutdown but I'm searching a way to make it switch between 2 different displays (main screen and video projector). How would I do this?
Thanks by advance.
Vanteuton
RST8
Re: Remote windows 10 from a pi
Tue Mar 07, 2017 11:01 am
vanteuton wrote:Hi,
using windows 10.
Thanks by advance.
Vanteuton
On win 7 / win 10 there is a cmdline exe called displayswitch and you can run displayswitch /internal or display switch /external, so lurking somewhere is an API to do it, so you'd need to figure out a way of getting the pi to tell it to run this command. I suspect it probably just writes some stuff to the registry.
Joe
vanteuton
Tue Mar 07, 2017 3:53 pm
RST8 wrote: so you'd need to figure out a way of getting the pi to tell it to run this command. I suspect it probably just writes some stuff to the registry.
Hi, thanks for the quick answer ! I already had the command but there are 2 days i'm spamming google looking for "how to access windows registry from lan / raspberry pi" and it seems that no-one wrote how to do that :(
Thanks again and pardon my english :roll:
Vanteuton
IanS
Thu Mar 09, 2017 11:44 am
How about using powershell commands? Google 'remote powershell from linux' for a number of ways the connection can be made.
321
Thu Mar 09, 2017 12:03 pm
Putting two shortcuts on each monitor/desktop might be a way you can toggle between the two provided you dont have the option to auto arrange shortcuts on the desktop enabled.
https://www.sevenforums.com/tutorials/3 ... reate.html
Another might be sending the Windows key + P through to the windows machine, if its possible to send windows key presses through your remote access software.
I dont think you need to use the registry, some software only reads the registry once and other software will read the registry every time it needs to look up a setting, its down to how the software is written.
