uzierek wrote: I just want to output power to the lamp and be able to switch it on on off with a code running in the background, or a sensor which would be in next development phase.
Then you have purchased the wrong thing. The device you have purchased is a USB to Serial adaptor.
If you wish to control the power to external devices then you have a few options.
1. A Bipolar Junction Transistor
2. A Field Effect Transistor (FET)
3. A Relay (Electro-mechanical switch)
And there are several other more specialized 'switches' depending on what you want to power, how much power it needs, AC or DC etc.
