Mon Mar 06, 2017 9:19 pm
The easiest way to make a working backup of a Raspbian card is to get another card and a USB adapter for it, plug it into the Pi and run the SD Card copier. Then you will have a card that will have identical contents to your current card.
(If running Raspbian Lite, you will need to install piclone and run that from the command line).
