wget https://github.com/kusti8/chromium-build/releases/download/netflix-1.0.0/chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb
sudo dpkg -i chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb
kusti8
I can confirm this works with libgcrypt11_1.5.0-5. I'm not sure about any other version.gkreidl wrote:Which libgcrypt version does it use (11 = Wheezy o 20 = Jessie)?
That's the Wheezie version and has been replaced in Jessie by libgcrypt20.knuxyl wrote:I can confirm this works with libgcrypt11_1.5.0-5. I'm not sure about any other version.gkreidl wrote:Which libgcrypt version does it use (11 = Wheezy o 20 = Jessie)?
It uses Jessie. Tested on the latest Raspbian Jessie pixel.gkreidl wrote:Which libgcrypt version does it use (11 = Wheezy o 20 = Jessie)?
$ sudo dpkg -i chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb
(Reading database ... 134347 files and directories currently installed.)
Preparing to unpack chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb ...
Unpacking chromium-browser (56.0.2924.84-0ubuntu0.14.04.1.1011) over (56.0.2924.84-0ubuntu0.14.04.1.1000) ...
dpkg: error processing archive chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb (--install):
trying to overwrite '/usr/share/pixmaps/netflix-launcher.png', which is also in package netflix-launcher 1.0-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for hicolor-icon-theme (0.13-1) ...
It's because you have Netflix-launcher installed. You have to remove it :cjan wrote:got errorCode: Select all
$ sudo dpkg -i chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb (Reading database ... 134347 files and directories currently installed.) Preparing to unpack chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb ... Unpacking chromium-browser (56.0.2924.84-0ubuntu0.14.04.1.1011) over (56.0.2924.84-0ubuntu0.14.04.1.1000) ... dpkg: error processing archive chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb (--install): trying to overwrite '/usr/share/pixmaps/netflix-launcher.png', which is also in package netflix-launcher 1.0-1 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Processing triggers for hicolor-icon-theme (0.13-1) ... Errors were encountered while processing: chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb
dpkg: dependency problems prevent configuration of chromium-browser:
chromium-browser depends on gconf-service; however:
Package gconf-service is not installed.
chromium-browser depends on libraspberrypi0; however:
Package libraspberrypi0 is not installed.
chromium-browser depends on libatk1.0-0 (>= 1.12.4); however:
Package libatk1.0-0 is not installed.
chromium-browser depends on libcairo2 (>= 1.6.0); however:
Package libcairo2 is not installed.
chromium-browser depends on libgconf-2-4 (>= 2.31.1); however:
Package libgconf-2-4 is not installed.
chromium-browser depends on libgdk-pixbuf2.0-0 (>= 2.22.0); however:
Package libgdk-pixbuf2.0-0 is not installed.
chromium-browser depends on libgtk2.0-0 (>= 2.24.0); however:
Package libgtk2.0-0 is not installed.
chromium-browser depends on libnspr4 (>= 2:4.9-2~) | libnspr4-0d (>= 1.8.0.10); however:
Package libnspr4 is not installed.
Package libnspr4-0d is not installed.
chromium-browser depends on libnss3 (>= 2:3.13.4-2~) | libnss3-1d (>= 3.
dpkg: error processing package chromium-browser (--install):
dependency problems - leaving unconfigured
Processing triggers for mime-support (3.58) ...
chromium-browser
For some reason Dropbox unshared it. Moved to github.hook69 wrote:Could you reupload the file? Looks like they've erased it.
Thank you
sudo apt-get update
Looks like a corrupted download. Delete the file and then try again.slainco wrote:First thanks for all the work
But stioll not working for me..
When i put the second line of command :
I got this message :
(Reading database ... 131670 files and directories currently installed.)
dpkg-deb (subprocess): cannot copy archive member from 'chromium-browser_56.0.2924.84-0ubuntu0.14.04.1.1011.deb' to decompressor pipe: unexpected end of file or stream
dpkg-deb (subprocess): decompressing archive member: lzma error: unexpected end of input
dpkg-deb: error: subprocess <decompress> returned error exit status 2
cannot copy extracted data for './usr/share/doc/chromium-browser/copyright' to '/usr/share/doc/chromium-browser/copyright.dpkg-new': unexpected end of file or stream
Go to the Start Menu, then Internet, and then Netflix Launcher.caporeira wrote:I have Pi2 and have installed all from first post.
Now, how to run Netflix (step by step) ?
I founded Netflix App but cost 3.69 Euro
It is going to be very slow on a Pi2. A Pi3 would speed it up and then I get around 20 frames or something like that.auredor wrote:Thank you Kusti8 for the package.
I did all the same than you. After few updates to get Pixel on my PI2, I've finally got Netflix working on it.![]()
However, the video is not playing very smooth. From browsse infomation, it looks that there are about 11 fps... even with Chrome user Agent selection
When lauching chromium-browser from a terminal, there are several errors related to the GPU : ERROR:browser_gpu_channel_host_factory.cc(113)] Failed to launch GPU process
So, I believe this is the cause of my issue. Looking on Internet, it seems there were similar cases but with previous Chromium version (43). Those were fixed by chromium update !!! I guess then it's supposed to be included with Chromium 56 ?
Thanks.
Pi2 is supposed to manage at least 1080p up to 30fps.kusti8 wrote:It is going to be very slow on a Pi2. A Pi3 would speed it up and then I get around 20 frames or something like that.auredor wrote:Thank you Kusti8 for the package.
Thanks.
