abelectronicsuk
External Antenna connector for the Pi Zero W
Sat Mar 04, 2017 2:05 pm
I have modified the new Raspberry Pi Zero W to add a U.FL antenna connector to use an external WiFi aerial with the new Pi and added more photos and the parts required to my blog at http://www.briandorey.com/post/Raspberr ... ntenna-mod
mahjongg
Re: External Antenna connector for the Pi Zero W
Sat Mar 04, 2017 2:59 pm
Great! I see from your blog that it does really work!
Note that by replacing the certified antenna with another uncertified antenna you have invalidated FCC certification, but as that is true for any radio device with a replaceable antenna it not a big deal, as long as you do not blame the RPF when they come knocking on your door. LOL :lol: :mrgreen: :ugeek:
Its really great, and I see that you used the tip I mentioned in the blog to turn the zero ohms reistor 90 degrees, unless of course you thought of that yourself.
I'm very happy this is possible, and isn't too difficult to do!
now see if an antenna for the FM radio function in the chip is also possible. :mrgreen:
bensimmo
Sat Mar 04, 2017 3:40 pm
What happens if you have them both connected up ?
abelectronicsuk
Sat Mar 04, 2017 4:00 pm
bensimmo wrote:What happens if you have them both connected up ?
The resistor link changes the port/antenna used so this mod disconnects the PCB antenna. if both are connected there would be a RF mismatch between the antennas which could damage the RF stages in the chip.
abelectronicsuk
Sat Mar 04, 2017 4:48 pm
mahjongg wrote: Its really great, and I see that you used the tip I mentioned in the blog to turn the zero ohms reistor 90 degrees, unless of course you thought of that yourself.
I didnt see your post about the resistor, it wasnt the easiest component to move, not sure what size it is but with the 0.5mm soldering iron tips it still was tricky to move!
The photo below shows the new modified board fitted to the barcode scanner pcb which has the adafruit touchscreen fitted on top so the onboard antenna would have been shielded by both PCB's.
alphanumeric
Sat Mar 04, 2017 6:28 pm
Working with SMT parts is always fun with just regular soldering iron. :| I may try that myself. When I finally get my hands on Zero W.
Sat Mar 04, 2017 7:19 pm
Given that zero ohm resistor is just a jumper would it not be easier to just leave it where it is, make a new bridge with a blob of solder and scratch a gap in the PCB trace in the direction you don't want to go?
Saves all that messing trying move the "resistor".
Unless you expect to want to undo the mod of course.
klricks
Sat Mar 04, 2017 7:32 pm
abelectronicsuk wrote:....... it wasnt the easiest component to move, not sure what size it is but with the 0.5mm soldering iron tips it still was tricky to move!....
I don't have a RPi 0W to verify this but the resistor is likely a 0 Ohm resistor which can be replaced by a wire or in a pinch a solder bridge.
Sat Mar 04, 2017 7:37 pm
That is what I just said.
If you just bridge it with a solder blob the old antenna is still connected. Hence my suggestion to scrape the PCB trace away.
alphanumeric
Sat Mar 04, 2017 7:41 pm
Assuming it is a resistor and not an inductor.
From the link
"On the Raspberry Pi PCB there is a component which appears to be a zero ohm resistor".
An inductor would measure zero of near zero ohms. It can be hard to tell sometimes exactly what something is when dealing with SMT components. If it is a resistor, you could just carefully cut it in half, with wire cutters or a dremel. Then unsolder each end one at a time. Then just solder in a wire jumper the other way.
Somebody from the RPF, that has access to a schematic could verify exactly what it is.
Sat Mar 04, 2017 7:53 pm
If you're removing the resistor completely why not connect a SPDT switch (or even header pins with a jumper) so you can choose between external or internal WiFi antenna.
alphanumeric
Sat Mar 04, 2017 7:59 pm
DougieLawson wrote:If you're removing the resistor completely why not connect a SPDT switch (or even header pins with a jumper) so you can choose between external or internal WiFi antenna.
That's fine for DC voltages etc. It doesn't always work so good for RF though. ;) Stray capacitance or inductance for example.
Sat Mar 04, 2017 8:11 pm
Ah, I've never worked with RF beyond the capacitor, coil and crystal on a MW AM crystal set in the 1970s.
Sat Mar 04, 2017 8:17 pm
It would have to be a very small SPDT switch. Like the size of that zero ohm resistor :)
alphanumeric
Sat Mar 04, 2017 8:21 pm
I'm a retired electronic technician. I worked in the installation and maintenance or electronic equipment used is civil aviation here in Canada. Basically all the ground based equipment an aircraft uses for takeoff, landing, navigation and communication. Instrument Landing Systems, RADAR, Navigation Beacons, VHF, UHF, MF, HF, etc. And the computers used for maintenance and control. A jumper pin, like what is used on the GPIO, will be an antenna at the right frequency. ;)
klricks
Sat Mar 04, 2017 8:26 pm
Heater wrote:That is what I just said.
Your post was not there when I clicked reply.
There is no need to scrape any trace away. Scrape what trace?
Bridging with solder or wire would have to be done by first removing the zero Ohm and then shorting across the 2 pads as shown in the photo in the OP........ Diagonally from the left pad to the lower pad leading to the external antenna connector. The pad on the right leads to the on board PCB trace antenna which would be disconnected when the 0 Ohm is removed.
abelectronicsuk
Sat Mar 04, 2017 8:27 pm
Heater wrote:It would have to be a very small SPDT switch. Like the size of that zero ohm resistor :)
The resistor is a 0201 size so need a switch 0.6mm x 0.3mm :)
At 2.4GHz a 1/4 wave antenna is only 31.25mm so adding a set of jumpers the size of a GPIO header would be getting close to the resonant frequency of the Wifi / bluetooth transmitters.
alphanumeric
Sat Mar 04, 2017 8:33 pm
Exactly, and set up standing waves etc and mess things up royally. In simple terms, it could detune the circuit to a point where it doesn't work at all. It would be like connecting the wrong antenna. AKA coat hanger, lol.
Sat Mar 04, 2017 8:53 pm
klricks,
You are not as lazy as me.
I would leave the zero ohm resistor in place. Make a solder bridge from the resistor to the pad to the south. Then slice the track to the right with an exacto knife. Job done.
digger72
Sat Mar 04, 2017 9:25 pm
Any idea on relative performance gain with external antenna.
CarlRJ
Sat Mar 04, 2017 9:37 pm
digger72 wrote:Any idea on relative performance gain with external antenna.
If you follow the link in the first post, he gives a nice table comparing signal strength between the internal and external antennas.
abelectronicsuk
Sat Mar 04, 2017 10:03 pm
Heater wrote:klricks,
If you leave the resistor in place and also use an external antenna it would half the impedance to the RF section which will damage the RF stages.
Sat Mar 04, 2017 10:07 pm
If I leave the resistor in place and short the route to the new antenna connection with a solder blob, I can then cut the trace to the on board antenna with an exacto knife. Job done. No worries with half impedance, etc.
solar3000
Sat Mar 04, 2017 10:40 pm
mahjongg wrote:Great! I see from your blog that it does really work!
Nonono! Don't LOL! This actually happened:
https://yro.slashdot.org/story/00/01/04 ... ow-by-blow
Antikythera
Sun Mar 05, 2017 12:16 am
That story is about an FM transmitter.
The chip on the Pi has a perfectly legal FM receiver
(but the antenna pin isn't connected to anything, so it can't be used)
