squirreltown
python IDLE/jessie
Fri Mar 03, 2017 5:56 pm
If i make a file in python IDLE 3.4.2 and run it
name='Red'
if len(name) == 4:
    print('oops!')
else:
    print(name)
it works fine.
Typing the same thing into the shell gets a syntax error - multiple statements found while compiling a single statement.
ghp
Re: python IDLE/jessie
Sat Mar 04, 2017 6:57 am
I looked around and found some hints on the web: seems to be that you can only copy-and-paste line-by-line into the Shell window, not a complete code fragment at a time.
Regards,
Gerhard
squirreltown
Sat Mar 04, 2017 8:06 pm
Thank you. Appreciate the reply.
Return to “Python”
