moelski
Chromium no longer startable over X11 Server
Fri Mar 03, 2017 7:33 am
Hi !
I recenty updated my Raspian and get the latest release of chromium which is 56.
Normally I use my pi in headless mode and connect via SSH and use a X11 server if I need an graphical application. (I use MobaXTerm btw ...)
In the past that worked like a charm with Chromium. But with the latest update I got this:
pi@raspberrypi:~ $ chromium-browser
bootstrap_helper: /usr/lib/chromium-browser/nacl_helper: Cannot open ELF file!  errno=2
[1:1:0303/072924.874290:ERROR:nacl_fork_delegate_linux.cc(315)] Bad NaCl helper startup ack (0 bytes)
[5870:5870:0303/072924.943894:ERROR:browser_main_loop.cc(495)] Failed to put Xlib into threaded mode.
[5870:5870:0303/072924.957006:ERROR:browser_main_loop.cc(272)] Gtk: cannot open display:
It worked well with the previous versions of chromium.
Any idea what´s wrong here ?
regards Dominik
moelski
Re: Chromium no longer startable over X11 Server
Fri Mar 03, 2017 8:49 am
Hi !
Just saw that my X Server was not working. But anyway after fixing that the problem still exists:
[1:1:0303/083458.248927:ERROR:nacl_fork_delegate_linux.cc(315)] Bad NaCl helper startup ack (0 bytes)
Received signal 11 SEGV_MAPERR 000000000094
#0 0x00005664f450 <unknown>
#1 0x00005664f3c8 <unknown>
#2 0x0000758ab1a0 <unknown>
[end of stack trace]
(chromium-browser:1027): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Failed to connect to socket /tmp/dbus-AHc6HRPBep: Verbindungsaufbau abgelehnt
[8:8:0100/000000.713469:ERROR:broker_posix.cc(41)] Invalid node channel message
[7:7:0100/000000.712941:ERROR:broker_posix.cc(41)] Invalid node channel message
Speicherzugriffsfehler
moelski
Tue Mar 07, 2017 5:37 am
Hi !
Has nobody an idea about this topic?
I can reproduce this on several raspberries ... :cry:
btw: Other applications like geany or monodevelop work like a chram. So it´s not the x11 forwarding which causes the problems.
Update:
Just installed a frisch Raspbian Image to a new SD card ... Same behaviour. :cry:
mob-i-l
Contact: Website Facebook Twitter YouTube
Fri Mar 10, 2017 3:53 pm
I couldn't start Chromium, but then i did dist-upgrade and now I can start, but I get errors:
$ chromium-browser
[1:1:0310/164529.455362:ERROR:nacl_fork_delegate_linux.cc(315)] Bad NaCl helper startup ack (0 bytes)
[2701:2701:0310/164541.538171:ERROR:sandbox_linux.cc(343)] InitializeSandbox() called with multiple threads in process gpu-process.
[2592:2633:0310/164611.771146:ERROR:upload_data_presenter.cc(77)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[2592:2633:0310/164614.152129:ERROR:upload_data_presenter.cc(77)] Not implemented reached in virtual void extensions::RawDataPresenter::FeedNext(const net::UploadElementReader &)
[2592:2764:0310/164626.997611:ERROR:object_proxy.cc(583)] Failed to call method: org.freedesktop.NetworkManager.GetDevices: object_path= /org/freedesktop/NetworkManager: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.NetworkManager was not provided by any .service files
Chromium: Version 56.0.2924.84 Built on Ubuntu 14.04, running on Raspbian 8.0
Have Pi0&1A&1B&1B+&2B&3B&4B w/ rasPiOS. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
plagasul
Sat Mar 11, 2017 12:24 am
I am having exactly the same problem.
I need to start chromium headless on boot. But I cannot even start it through CLI, the error is the same:
[1:1:0311/011456.810221:ERROR:nacl_fork_delegate_linux.cc(315)] Bad NaCl helper startup ack (0 bytes)
[11710:11710:0311/011457.178206:ERROR:browser_main_loop.cc(495)] Failed to put Xlib into threaded mode.
[11710:11710:0311/011457.190579:ERROR:browser_main_loop.cc(272)] Gtk: cannot open display:
If I run a vncserver, and log into it with another computer remotely, I see the GUI, I can open a terminal and start chromium. Then it does start.
To be able to do this is crucial for what I am doing at the moment.
Any help would be greatly appreciated.
plagasul
Sat Mar 11, 2017 10:49 am
running DISPLAY=:0 before chromium, seems to work for me
someone should point us to some good useful X info
thx
moelski
Wed Mar 15, 2017 6:24 am
Hi !
Don´t understand the sense of this ...
Display 0 is usually the attached display and not the display for the x11 forwarding.
So this won´t help at all ...
Dominik
ShiftPlusOne
Wed Mar 15, 2017 1:44 pm
moelski
Fri Mar 17, 2017 8:31 am
@ShiftPlusOne:
I opened that issue on github ;)
But there is also no solution available ... :cry:
At the moment it seems that this problem only occurs on Windows Systems.
But that´s all I can tell right now ...
ShiftPlusOne
Fri Mar 17, 2017 5:25 pm
The John (the dev) has reproduced the issue and has a fix in mind. I think it might be fixed with the next image, or shortly after.
Return to “Raspberry Pi OS”
