jduell
YCbCr on DPI Output
Thu Mar 02, 2017 2:00 am
Hello all!
I have a fairly specific need to output YCbCr, instead of RGB, on the DPI bus for a video playback application. Unfortunately, for my application the DPI output is the only cost effective solution and outboard color space conversion may not be possible. As an experiment I tried specifying hdmi_pixel_encoding as YCbCr Full in config.txt. This didn't seem to work and I knew it was a long shot.
Does anyone know if there's support for YCbCr output on the DPI bus? Alternatively, does anyone know if omxplayer (or similar) is capable of doing a color space conversion prior to output?
Thanks!
-Jason
aBUGSworstnightmare
Re: YCbCr on DPI Output
Sat Mar 04, 2017 12:56 pm
jduell wrote:Hello all!
Thanks!
-Jason
OMXPlayer doesn't use frame buffer, that's why your output looked incorrect most likely. You may want to try with other players like VLC or Mplayer.
Return to “Advanced users”
