Hi.
I have decided to learn everything related to Raspberry Pi.
I bought a Computer Module with the development kit.
Are useful books about Raspberry PI?
Is there a guide or book that focuses only on the computer module?
I hope you bought the CM3L kit so you can boot an Operating System from a SD CardDominusDRR wrote:Why can it be so difficult or different?
Hi,fruitoftheloom wrote:I hope you bought the CM3L kit so you can boot an Operating System from a SD CardDominusDRR wrote:Why can it be so difficult or different?
https://www.element14.com/community/doc ... e-module-3
It has no network interfaces built in, only one USB Host Port and considerably more expensive than a RPi 3B.
You can learn to configure an OS on any Pi, and the advice to start with a Pi3B is sound. Learn the configuration on a Pi3B with an SD card so your mistakes can be quickly and easily corrected. Take and keep good notes. They will stand you in good stead when you move on the the CM boards.DominusDRR wrote: Hi,
Thank you very much for answering.
I'm aware that it doesn't have some 'peripherals'.
At the same time I'm interested in learning to configure the OS correctly.
Then I will design my hardware to add connectivity functions to the module.
Thanks again.
