I keeping getting hung on the setup step getting the 'mode2 -d /dev/lirc0' command to detect anything (of course lircd is not running when I try this).
I have the IR receiver power pins wired to 3.3V and GND pins. The data pin is wired to GPIO physical pin 18 (BCM 24). I have an oscilloscope between GND and the data pin and I see pulses when I press a remote button. In idle state, the scope is reading about 1.98V. When I press a button, the pulses go from 1.98V to near 0V.
I verified the following line in my /boot/config.txt:
# Uncomment this to enable the lirc-rpi module
dtoverlay=lirc-rpiCode: Select all
pi@raspberrypi:~ $ dmesg | grep -i lirc
[ 1.959740] systemd[1]: Cannot add dependency job for unit lircd-setup.service, ignoring: Unit lircd-setup.service failed to load: No such file or directory.
[ 2.873137] lirc_dev: IR Remote Control driver registered, major 243
[ 2.881714] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.934935] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 3.935269] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 3.935274] lirc_rpi: driver registered!
pi@raspberrypi:/etc/lirc $ lsmod | grep lirc
lirc_dev 10583 1 lirc_rpi
lirc_rpi 9032 0
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_in_pull=up
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_in_pull=down
