Thanks for your answer. I understand what you say but my thought was completely the opposite. Why not scan channel 13 for the whole world when in the US and some other countries it wouldn't list any WIFI networks on there anyways. I was already searching for a NOOBS forum so thanks for that link. I will place my question there.DougieLawson wrote:The reason it's least used is that it's not supported by ANY American equipment. NOOBS uses a channel in the range 1 to 11 so it's compatible Worldwide.
If you need it changed or configurable open an issue at: https://github.com/raspberrypi/NOOBS/issues they should be able to ask you what country you're in and work it out from a table of allowable channels.
Because it is illegal to use that channel in the US. Even for scanning.maicod wrote:Why not scan channel 13 for the whole world when in the US and some other countries it wouldn't list any WIFI networks on there anyways.
You must use the correct country setting for your location, to ensure compliance with local WiFi regulations.robert82h wrote: ↑Tue Dec 26, 2017 11:15 pmSorry for bringing up this old thread again, but it was my #1 search result so I'd figure I post my solution here. Not scanning channel 13 is a show-stopper for many, and I suppose a lot of people will never realize what the problem is if NOOBS does not list their Wifi network.
You can fix it by switching from the NOOBS screen to the recovery console (Ctrl+Alt+F2), logging in (root : raspberry), edit /settings/wpa_supplicant.conf, add a line "country=DE", and reboot (Ctrl+Alt+Del). Et voilà - after the reboot, the Wifi dialog shows the channel 13 networks!
