Beemccullah
corrupted ancient card, how to re-install.
Sun Feb 26, 2017 1:36 am
This is my 1st raspberry pi so please don't be to harsh. I have a raspberry pi 3 b, I have it connected to a 5 inch. Touch screen I bought off this website called wish. I also bought a pre installed noobs card. Now the first time I started the pi up it did ask me to choose any kind of os or settings or any thing for that matter just started into this desktop setting with just the trash bin on the desktop I believe it is Jesse but thats all I know but my issue is I turned it off 1 night and when I turned it on back on it went to this kinda like terminal setting I know longer have a graphical interface how can I get back to a graphical interface I have tried sudo raspi-config and then changed the setting to graphical but that did nothing I also want to change the os to kali Linux any help is much appreciated I have been trying to figure this out for 3 days
Re: Small issue
Sun Feb 26, 2017 7:05 am
My advice is to start afresh, as you have no idea the age of the NoobS installer / chooser which was on the SD Card:
https://www.raspberrypi.org/downloads
RPi 4B 4GB (SSD Boot)..
B.Goode
Re: Small issue
Sun Feb 26, 2017 8:57 am
For the Kali penetration testing OS, see the documentation on their own website: http://docs.kali.org/kali-on-arm/kali-l ... pberry-pi2
Note that they say -
Kali is a Linux distribution specifically geared towards professional penetration testers and security specialists, and given its unique nature, it is NOT a recommended distribution if you’re unfamiliar with Linux
Beemccullah
Re: Small issue
Sun Feb 26, 2017 11:17 am
Thank you so much... plz be patient with me how can I redo the noobs sd card I have never done it before. Thanks again
Beemccullah
Re: corrupted ancient card, how to re-install.
Thu Mar 02, 2017 9:02 am
Ok so last night I tried to download noobs and then tried to download a img burner but I think the one I downloaded is no good I believe it's called wins 24 or something like that any suggestions on which img burner I should download
Thu Mar 02, 2017 9:28 am
Beemccullah wrote:Ok so last night I tried to download noobs and then tried to download a img burner but I think the one I downloaded is no good I believe it's called wins 24 or something like that any suggestions on which img burner I should download
NoobS does not require an .IMG Burner, you are reading the wrong Tuturials ??
https://www.raspberrypi.org/downloads/noobs
BMS Doug
Thu Mar 02, 2017 9:30 am
Raspberry Pi's quick start tutorial recommends using SD Formatter 4.0 to reformat your SD card ready for the new NOOBS install.
Doug.
Building Management Systems Engineer.
peterlite
Thu Mar 02, 2017 10:54 am
You can format an micro/SD/HC?XC card to the SD standard format by placing the card in a camera and hitting format. SDXC cards will be formatted as ExFAT instead of FAT because using the proprietary patent restricted ExFAT is the standard for SDXC.
Return to “Beginners”
