Genius23008 wrote:OMXplayer ideally works with 64MB of RAM allocated to the GPU. OMXplayer used to not work at all for me - after assigning 64 instead of 16 and renaming my video files, I can watch 1080p without any lag at all. Has your movie file got spaces in it's name? Try removing them and playing it.
Hope that helps.
Yeah that's why I'm somewhat confused on why this is happening. My files don't have spaces in their names, but thanks for the thought.
fredjam wrote:I use the 192/64 memory split and I can play HD video with surround sound without any lag.
The must be something in your setup that is consuming CPU processing power. In any case
you need to give a lot more information about your set up. What are you playing these movies
from? Where did you get the movie files from? Is your pi over clocked? Are you playing them
and the sound through HDMI?
The movies are being played straight from the SD card. I got the videos via torrent and direct download from various sites. The videos run perfectly fine on my PC. My pi isn't overclocked, and the sound is coming through HDMI.
