sd_israr
RPi3 in industrial product.
Sat Feb 25, 2017 1:11 pm
I am planning an industrial product which will be used in very high temperature.Can i use Raspberri Pi 3 in that .Will it sustain high temperature >185'C.
Re: RPi3 in industrial product.
Sat Feb 25, 2017 2:43 pm
No.
The printed circuit board is only good for 130C http://thegundcompany.com/files/index.c ... 0Grade.pdf
See discussion all around the web.
http://electronics.stackexchange.com/qu ... re-on-fr-4
https://www.electronics-related.com/sho ... 2182-1.php
I suspect some of the components might conk out at those temperatures anyway.
W. H. Heydt
Sat Feb 25, 2017 5:37 pm
I was looking up various sties to check availability of CM3/CM3L boards. One site had the spec that the design temperature range is -25C to +80C. A Pi3B certainly wouldn't have a wider specified range. Of course, we all know that a Pi will operate at temps below -25C, but I wouldn't want to bet on anything much over the +80C on the high end and *certainly* not +185C.
My usual rule of thumb is that the Pi is fine in any temperature in which it's owner can "operate". I will admit to curiosity about where the OP wants to use a Pi that gets to 185C (I can think of such places, I'm just wondering about this specific use).
Sat Feb 25, 2017 5:42 pm
W. H. Heydt wrote:I was looking up various sties to check availability of CM3/CM3L boards. One site had the spec that the design temperature range is -25C to +80C. A Pi3B certainly wouldn't have a wider specified range. Of course, we all know that a Pi will operate at temps below -25C, but I wouldn't want to bet on anything much over the +80C on the high end and *certainly* not +185C.
Kiln controller? Anyway you would be hard pushed to find ANYTHING electronic that can withstand that sort of temp without some sort of cooling system.
DavidS
Sat Feb 25, 2017 5:46 pm
With the exception of a Parallax Propeller (P8X32A), which has been tested to be reliable to even higher temperatures. Wish I still had the link to the thread in the Parallax forum where Parallax tested the Propeller to extreme temperatures. Turned out that the Propeller MCU could handle temperatures higher than the crystal could remain stable.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
Sat Feb 25, 2017 5:59 pm
Most chips are good for 150degC (they are tested in ovens!), it's the rest of the stuff around them that would fail. Although high temps will dramatically reduce chip lifetime.
Ernst
Sat Feb 25, 2017 6:29 pm
I think you may run into a problem:
The melting point of most solder is in the region of 188°C (370°F) and the iron tip temperature is typically 330°C to 350°C (626°F to 662°F).
source: https://technick.net/guides/electronics ... _to_solder
The road to insanity is paved with static ip addresses
sd_israr
Sat Feb 25, 2017 7:22 pm
So, it has to be under 110'C,i think.Beyond that cooling system is mandatory.I will ask my client to give compliance for cooling
system.
CarlRJ
Sat Feb 25, 2017 7:24 pm
The Pi will operate properly in any temperature environment for an extended period of time so long as you are standing there holding the board in your bare hands. It'll probably also work a bit above and below that temperature range, thus comfortably exceeding the needs of its intended use cases.
DavidS
Sat Feb 25, 2017 8:41 pm
CarlRJ wrote:The Pi will operate properly in any temperature environment for an extended period of time so long as you are standing there holding the board in your bare hands. It'll probably also work a bit above and below that temperature range, thus comfortably exceeding the needs of its intended use cases.
While the cooling system of the human body would indeed keep it in operating temperature so long as in direct contact with the surface of a living human body, the human body may be the weak link in the equation, as I do not know how long the human body can stay functional at those temperatures. In other words while the stated suggestion is workable, you would be replacing the living human body component often do to frequent complete system damage on that component, that is catastrophic and permanent.
