wrybread
Any way to bring it up w/o a monitor? [solved]
Fri Feb 24, 2017 8:49 pm
I have a headless Pi, and I accidentally disabled its ethernet connection. Oops!
Is there any way to re-enable it without connecting a keyboard and monitor, which unfortunately I don't have here?
Thanks for any help.
Solved through wifi. Had to configure a local router to match a network that the Pi had been configured for. Worked!
Ernst
Re: Arg, I disabled eth0. Any way to bring it up w/o a monit
Fri Feb 24, 2017 9:05 pm
It depends on what you did. If you configured the interface down then it will be fixed with a power cycle.
Anything else may need divine intervention.
The road to insanity is paved with static ip addresses
