Thu Feb 23, 2017 9:29 pm
I reinstalled the Raspbian OS and setup all of the localization options before joining a wifi network. Still no luck, only typing an ip address works. Here are the results of the commands you listed.
pi@raspberrypi:~ $ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:32:95:22 brd ff:ff:ff:ff:ff:ff
inet6 fe80::6761:477d:e402:808d/64 scope link tentative
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:67:c0:77 brd ff:ff:ff:ff:ff:ff
inet 10.10.32.37/23 brd 10.10.33.255 scope global wlan0
inet6 fe80::371b:47fb:8c8:87d4/64 scope link
pi@raspberrypi:~ $ ip route
default via 10.10.32.1 dev wlan0 metric 303
10.10.32.0/23 dev wlan0 proto kernel scope link src 10.10.32.37 metric 303
pi@raspberrypi:~ $ sudo ping -c3 $(ip route | awk '/default/ {print $3}')
PING 10.10.32.1 (10.10.32.1) 56(84) bytes of data.
64 bytes from 10.10.32.1: icmp_seq=1 ttl=255 time=5.12 ms
64 bytes from 10.10.32.1: icmp_seq=2 ttl=255 time=4.85 ms
64 bytes from 10.10.32.1: icmp_seq=3 ttl=255 time=5.43 ms
--- 10.10.32.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 4.856/5.140/5.439/0.245 ms
pi@raspberrypi:~ $ sudo ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=47 time=26.0 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=47 time=25.4 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=47 time=26.1 ms
--- 8.8.8.8 ping statistics ---
rtt min/avg/max/mdev = 25.421/25.874/26.104/0.370 ms
pi@raspberrypi:~ $ sudo ping -c3 google.com
ping: unknown host google.com
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain wcbvi.k12.wi.us
nameserver 127.0.0.1
pi@raspberrypi:~ $ for i in $(awk '/nameserver/ {print $2}' /etc/resolv.conf); do ping -c3 $i; done
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.146 ms
64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.114 ms
64 bytes from 127.0.0.1: icmp_seq=3 ttl=64 time=0.105 ms
--- 127.0.0.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1998ms
rtt min/avg/max/mdev = 0.105/0.121/0.146/0.021 ms
