Wed Feb 22, 2017 6:32 pm
One disadvantage of not using a standard 40-pin header, as provided on the normal Pi's, is that you can't use a ribbon cable to connect to a breadboard, but if you're not wanting to use a breadboard, it's not a disadvantage.
Another disadvantage of not using a header is that you can't unplug soldered wires, but if you want it permanently connected, again it's not a disadvantage.
One advantage of soldering directly to the Pi is it ends up much thinner.
If you were to keep the pins on the wire and solder the pins to the Pi, you'd lose that advantage.
Using that solid-core wire would be ok if you aren't wanting much movement between the Pi and the sensors - but if there is movement, solid-core wire is more likely to break, either somewhere in the middle (which can be difficult to find, inside the insulation) or just by the soldered joint.
Flexible multi-core wire is just that - more flexible, less likely to break.
I would do exactly as you have done, except that I might have bought the ribbon without the pins attached.
But, having been soldering stuff for half a century, I've forgotten pretty much all of the problems I had when I started out (at Yorkshire Television I was known as the Dry Joint King)
Still, perhaps the following might help.
Start by stripping more insulation off the end of the wire then you think you need - about a centimetre is good.
Don't remove it all the way - use that bit of insulation to twist the wire. It gives the twist a nice professional look, but more to the point it makes it more likely to slip through the hole in the board.
It's sometimes worth tinning the wire (putting some solder on it) before putting it through the hole - it holds the wires together, stops them fraying apart, and makes sure there isn't going to be a dry joint.
Soldering a wire to a board requires at least five hands - one to hold the board, one to hold the wire, one to hold the solder, one to hold the iron, and one to answer the phone that always starts ringing in the middle of things.
So get a vice to hold the board.
Poke the wire through the hole and bend it so it doesn't fall out.
Apply iron then solder.
Switch off your phone.
