kliodd
USB HD transfer rate very slow
Sun Sep 16, 2012 12:20 pm
I have a USB 3.0 2TB powered HD connected to the PI. And it is slow, transfering to it takes ages. Typical speed is 350 to 400 KB/ps. When I transfer directly to the SD card it goes ok, 5MB/ps. And transfering from the SD to the USB HD it again goes into slow mode.
When connected to a laptop the HD performs, so the problem must be with the PI somehow.
Have been searching the forums for a solution, but all are fairly technical and involve Linux coding. And I only have the Raspbmc.
Clues from different forums include:
1. USB HD drains power from the PI although itself is powered
2. Must have a USB powered hub to connect the HD
3. Firmware bugs
All suggestions are welcome and greatly appreciated :)
elatllat
Re: USB HD transfer rate very slow
Sun Sep 16, 2012 1:15 pm
dmesg
mount
df -h
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
kliodd
Sun Sep 16, 2012 1:54 pm
elatllat wrote:
dmesg
mount
df -h
How can i run this on my Pi with Raspbmc and what does it do?
kliodd
Tue Sep 18, 2012 9:21 pm
I still have this problem, have tried fitting a USB hub, this did not change anything.
Also, found another strange thing, I mounted a USB thumb drive, went into the file manager program. There I copied from the USB thumb drive to the USB HD, this went slow as always. But then I tried the other way, reading from the HD to the thumb drive, this went much faster, as one would expect in fact.
ghans
Tue Sep 18, 2012 9:36 pm
Perhaps reformating it to ext4 can help.
How does this show up in Windows ? As a NTFS drive ?
NTFS is cpu-intensive on the Pi platform.
ghans
piglet
Tue Sep 18, 2012 10:25 pm
ghans wrote:NTFS is cpu-intensive on the Pi platform.
Aha! Thanks. I've got the same problem. Will try ext4.
encryptix
Tue Sep 18, 2012 10:38 pm
similar problem (& solution) to http://forum.stmlabs.com/showthread.php?tid=2819 ?
ghans
Wed Sep 19, 2012 6:22 am
If you that with ext4 , you should easily get 6-7 mbps .
Did you try ntfs-3g instead of ntfs ?
ghans
