nabili
Serial port use with pyserial
Tue Feb 21, 2017 9:30 am
Hi everyone!
I'm a begginer with the raspberry pi (I own version 3, running Jessie) and I try to comminucate with a LoRa module taking AT commands that we write on the USB serial port.
To do so, I've wrote a small script in python (v 2.7.9) using the pyserial library (v 3.2.1) :
import serial
# Set up the connection to the dongle
dongle = serial.Serial(port="/dev/ttyUSB1",baudrate=38400,timeout=0,rtscts=0,xonxoff=0)
# get help
dongle.write('help')
# Close the connection
dongle.close()
But when I execute it, nothing is happening, for now I'm just trying to write something on the serial port, even if it's gargage. Also I've noticed that on minicom or putty, I can read data from the USB module (It send a start message at each reset) but I can't write to it.
Also, I've tried to activate/desactivate the shell login from serial, it's not fixing the problem
Any idea on what I've possibly did wrong?
Thanks ;)
nabili
Re: Serial port use with pyserial
Tue Feb 21, 2017 9:51 am
Also, the configuration of the device :
Baud Rate : 38400
Data : 8 bits
Parity : None
Stop : 1 bit
Flow control : None
End line character : LF
ghp
Tue Feb 21, 2017 1:51 pm
if minicom can receive from the module, but no writes are possible, then check the docs if there is a mismatch in line ending (crlf, lf). Or perhaps the data stream needs some special chars to switch into at command mode (in old hayes modems, this has been '+++' or alike).
For the python program, check whether /dev/ttyUSB1 or /dev/ttyUSB0 is the correct connection. Should be the same as you use in minicom (and close minicom when trying to run the python code).
Regards,
Gerhard
Davies
Wed Feb 22, 2017 10:51 am
does python return the response from an AT write command without additional code?
im unsure, but i think even when you have a successful write through python you dont see unless you catch the response and print it to console.
what happens if you try,
import serial
response = dongle.readline()
dongle.close()
print response()
this works for my sim800 device to detect if its switched on but i write AT which should return OK if its on but returns AT instead, im unsure if it yeilds the response or just the input that was wrote . also i have to call this multiple times on first boot to get a response.
perhaps you may need to use PIPE or something as such.. maybe dongle.readlines() to see more than 1 line
Return to “Python”
