Sinisa
Switch button on GPIO, short press / long press
Mon Feb 20, 2017 11:11 am
I need to run one script file after short press of switch button and another one after long press.
GPIO pins that i'm using are 25 and 26.
I have managed to run this Python code and it works well for just one script:
#!/bin/bash
exec > >(tee -a /home/pi/Skripta/log.txt)
exec 2>&1
echo Restart  `date`
sudo python - <<END
import time
import RPi.GPIO as gpio
gpio.setmode(gpio.BCM)
gpio.setup(7, gpio.IN, pull_up_down=gpio.PUD_UP)
print "wait for 2 seconds"
buttonReleased = True
while buttonReleased:
    gpio.wait_for_edge(7, gpio.FALLING)
    buttonReleased = False
    for i in range(20):
        time.sleep(0.1)
        if gpio.input(7):
            break
gpio.cleanup()
END
echo `date`. reboot...
sudo sh pi/Desktop/script1.sh
How can i expand it for short/long press?
Signature
thagrol
Re: Switch button on GPIO, short press / long press
Mon Feb 20, 2017 3:58 pm
I had a similar requirement and did it like this: (scroll down for example of using the class)
#!/usr/bin/env python
import gpiozero
import time
class cmdbutton(object):
    def __init__(self, pin, press, hold):
        self.__button = gpiozero.Button(pin,
                                        pull_up=True,
                                        bounce_time=0.050,
                                        hold_time=2.0)
        self.__press = press
        self.__hold = hold
        self.__press_time = None
        self.__sw = switch
        self.__button.when_held = self.__on_hold
        self.__button.when_pressed = self.__on_press
        self.__button.when_released = self.__on_release
    def __on_press(self):
        # button pressed
        self.__press_time = time.time() - self.__button.active_time
    def __on_release(self):
        # short press
        if time.time() - self.__press_time < 0.5:
            os.system(self.__press)
    def __on_hold(self):
        # button held
        os.system(self.__hold)
    def close(self):
        self.__button.close()
if __name__ == '__main__':
    btn = cmdbutton(pin=25,
                    press='echo foo',
                    hold='echo bar')
    try:
        while True:
            time.sleep(1)
    finally:
        btn.close()
Attempts to contact me outside of thes forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
B.Goode
Mon Feb 20, 2017 4:16 pm
The gpiozero python library can help you do this.
See: viewtopic.php?f=32&t=152046
texy
Tue Feb 21, 2017 8:02 am
Sinisa wrote:Hi,
#!/bin/bash
exec 2>&1
echo Restart  `date`
sudo python - <<END
import time
    for i in range(20):
        time.sleep(0.1)
        if gpio.input(7):
            break
gpio.cleanup()
END
Not sure where this code came from, although, yes it is python, the shebang on the first line isn't correct - see thagrols correct example.
https://en.wikipedia.org/wiki/Shebang_(Unix)
Texy
thagrol
Tue Feb 21, 2017 1:45 pm
Hate to disagree with you texy, but the op's shebang is correct. That code is bash with embedded python (via a here document).
Seems a convoluted way of ding things to me. Especially when it could probably be done either in bash or python.
texy
Tue Feb 21, 2017 2:08 pm
:oops:
Sinisa
Fri Feb 24, 2017 9:07 am
Thank you for answers.
I didn't found a way to run it just from bash.
Could anyone give me an example for bash, please?
Signature
Sinisa
Mon Mar 20, 2017 11:58 am
X.Org X Server 1.17.2
Release Date: 2015-06-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.8.11-2-ARCH armv7l Raspbian
Current Operating System: Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l
Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xf95611a3 smsc95xx.macaddr=B8:27:EB:56:11:A3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 January 2016  01:32:44PM
xorg-server 2:1.17.2-1+rpi1 (http://www.debian.org/support)
Current version of pixman: 0.33.3
    Before reporting problems, check http://wiki.x.org
    to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar 10 15:21:19 2017
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
modprobe: FATAL: Module g2d_23 not found.
This is error that i get after short or long press in terminal. Could anyone help me solve this, please?
Signature
