Hexgen
GPIO No such file or directory
Sun Feb 19, 2017 8:17 pm
So this is driving me insane.
I have an LED on GPIO 21.
root@RP0:/sys/class/gpio/gpio21# echo "out" > direction
root@RP0:/sys/class/gpio/gpio21# echo "1" > value
LED lights up.
However;
root@RP0:/sys/class/gpio/gpio21# echo "out" > /sys/class/gpio21/direction
-bash: /sys/class/gpio21/direction: No such file or directory
Anyone know what's going on here? I currently cannot access any GPIO with Node.JS, C++ or anything other than going to the directory in a terminal and switching it there.
It does not matter if I set all GPIO as unexport or individually;
root@RP0:/sys/class/gpio/gpio21# echo "21" > /sys/class/gpio/export
-bash: echo: write error: Device or resource busy
root@RP0:/sys/class/gpio/gpio21# echo "21" > /sys/class/gpio/unexport
root@RP0:/sys/class/gpio/gpio21# echo "out" > "/sys/class/gpio21/direction"
but;
root@RP0:/sys/class/gpio/gpio21# echo "0" > value
LED turns off.
wtf!
Anyone else seen this? I have searched, but alas nothing works.
Re: GPIO No such file or directory
Mon Feb 20, 2017 7:24 am
Hexgen wrote:root@RP0:/sys/class/gpio/gpio21# echo "out" > /sys/class/gpio21/direction
Yes, you will get that error if you don't put the correct full path for the pseudofile /sys/class/gpio/gpio21/direction.
Hexgen
Mon Feb 20, 2017 7:53 am
In my defence I was super tired. Still though, wow.
Thanks rpdom!
Hexgen
Mon Feb 20, 2017 7:15 pm
I would like to add, for clarity, that my initial confusion was around elevated privileges. I was accessing GPIO via C++ and standard out was reporting that the pin I was setting was 0, irrespective of what I set it to.
I had omitted "sudo" and while my C++ program ran happily, writing to GPIO under the default "pi" user is not permitted.
This is what I get writing to the (virtual) file system and not checking for errors.
Mon Feb 20, 2017 7:31 pm
Hexgen wrote:In my defence I was super tired. Still though, wow.
I get that way sometimes. Stare for hours at a problem and find no solution.
Then I walk away, go do something else for a while, look at another problem. After a reasonable break I come back to the original problem and the lightbulb goes on (or I wake up in the middle of the night grab a notepad)
Just saying, I'm very familiar with that situation :-)
jojopi
Mon Feb 20, 2017 8:18 pm
Hexgen wrote:I had omitted "sudo" and while my C++ program ran happily, writing to GPIO under the default "pi" user is not permitted.
In the recommended images, the pi user is a member of the gpio group, and can access the /sys/class/gpio/ files without sudo.
When exporting the pins inside a program, however, there can be a race condition. The files are initially created by the kernel as root:root, and then it takes a second or so for udev to apply the correct permissions. You may need to insert a delay or a call to "udevadm settle" between export and first use.
