danb1983
How to install opensuse on noob?
Wed Feb 15, 2017 1:27 pm
I am trying to create a multi-boot sd card with noob and cannot seem to get opensuse leap 42.2 to install. The image I download is from https://en.opensuse.org/HCL:Raspberry_Pi3. This version of opensuse seems to be using U-BOOT which is always looking for partition #2. Any help would be appriciated.
procount
Re: How to install opensuse on noob?
Wed Feb 15, 2017 2:17 pm
I hit this issue as well on Arch64 which also uses U-Boot.
I think the issue is that the boot script for U-Boot is built into the image, so it requires the U-Boot image to be modified after the image has been installed and the partition numbers are known, or another U-Boot image to be used that allows the partition number to be specified separately.
danb1983
Sat Feb 18, 2017 4:59 pm
Unfortunately I am not familiar with uboot. Do you know how I could do that?
Thanks,
Return to “openSUSE”
