Hello All,
I'm trying to access and configure a Pi 3 or the first time, headless. I've loaded the Raspbian "Jessie" image on a 32 GB SD card using Win32 Image, inserted that into my Pi, powered it up and Ethernet cabled it to my router.
I get solid red power light and a blinky green light next to that, as well as solid yellow and blinky green lights at the Pi's LAN port.
Although it appears my router is assigning a dynamic IP, I've been able to find the Pi's IP addy. I used Advanced IP Scanner first, but didn't see anything listed at being from "Raspberry Pi Foundation". Therefore, I looked in my router config and found the IP address with the manufacturer info listed, noting that the IP addy I saw there for "raspberrypi" was, in fact listed in the scanner, but w/o ownership.
I tried accessing my Pi using Putty in SSH mode, but the request times out. I never get the login prompt or the warning from Putty about an unknown connection.
I've been using this thread for help: viewtopic.php?t=116724&p=795133
Ultimately, I want to use my Pi as an OpenVPN Server with ExpressVPN.
Any assistance, greatly appreciated!
NBUK
