hei, i'm new with RPi, so i wanna build cluster, but i heard using power supply less that 2A is not recomended.
is it true ?
Which model Pi? And how many in a cluster?adeguntoro wrote:hei, i'm new with RPi, so i wanna build cluster, but i heard using power supply less that 2A is not recomended.
is it true ?
The raspberry 5.1V 2.5A power supply has no problems to feed a headless Pi3 with 4x Pi Zero on a Clusterhat.tweak42 wrote:Which model Pi? And how many in a cluster?adeguntoro wrote:hei, i'm new with RPi, so i wanna build cluster, but i heard using power supply less that 2A is not recomended.
is it true ?
For the Pi 3 it's recommended 2.5A, to cover powering connected usb devices, but running headless in a cluster it could get by with less. In contrast a Pi Zero could run off 500mAh of a powered usb port.
i'm using 4 RPi 3 model B, and i'm gonna use Orico dcv-4u..tweak42 wrote:Which model Pi? And how many in a cluster?adeguntoro wrote:hei, i'm new with RPi, so i wanna build cluster, but i heard using power supply less that 2A is not recomended.
is it true ?
I'm not sure what they mean by "improve output voltage" but I suspect that it means that they increase the voltage, if that increase takes it above 5.25V you will start having problems with your Pi.Intelligent IC and output compensation
Smart charging, amazing experience
Built-in intelligent IC ensures excellent performance and recognizes all kinds of 5V devices to deliver ideal current of up to 2.4A; improve output voltage when current is more than 1A to compensate the loss. Being tested, output efficiency of smart charging port is better than 80% products on the market, safe, smart and energy-efficient.
it's hard to find 2A for each port in Indonesia, if i can find it, it will cost me more than $40..BMS Doug wrote:I'm not sure if I would risk that.I'm not sure what they mean by "improve output voltage" but I suspect that it means that they increase the voltage, if that increase takes it above 5.25V you will start having problems with your Pi.Intelligent IC and output compensation
something like this might be better
That one certainly looks nice, but I couldn't find anything on the site about how much it costs or how to order one. Do you know where the company is based?adeguntoro wrote:okay, i find someting interesting this http://www.orico.cc/goods.php?id=4879..
on web, they said outputs is 5V and 2.4A for each port..
what do you thing ??should i buy it ??
For what it is worth, I think 1.5A for a Pi3 is quite sufficient if there are no (non-trivial) USB peripherals attached. Most text I've read so far talks in terms of "Well, of course, you're going to have a few things, like a hard disk and what not attached, so you will need at least a 2.5A power supply".Gavinmc42 wrote:5V6A 30watts
That's total, so if you use 4 Pi3's then only 1.5Amp each.
You might get away with it, or it might work with only 3 plugged in.
Should work with 2 Pi3's.
Depends what's plugged into the 3's and what code they are running
Both of my 2.4A power adapters can maintain 5.3v if I put a solid 2A resister load on them. According to this very through video review, the voltage does go up the more you draw to compensate for the loss from connectors and cable lengths. It looks pretty well made assuming one can get a authentic unit for a reasonable price.BMS Doug wrote:I'm not sure if I would risk that.I'm not sure what they mean by "improve output voltage" but I suspect that it means that they increase the voltage, if that increase takes it above 5.25V you will start having problems with your Pi.Intelligent IC and output compensation
