I want to install Arch on pi2. I installed it via PINN. Installation went fine, but after reboot nothing happens. PI2 gives red led light.
Is there an .img I can download of arch for pi2?
How to fix this?
Welcome, Arch Linux Arm stopped offering .IMG files a lomg time ago. They assume you have a Linux Machine to create a bootable SD Card:carsten888 wrote:I want to install Arch on pi2. I installed it via PINN. Installation went fine, but after reboot nothing happens. PI2 gives red led light.
How to fix this?
I've seen that, but am on windows, so downloaded from the url at 5, unpacked and wacked that on the sd card. same result.They assume you have a Linux Machine to create a bootable SD Card:
https://archlinuxarm.org/platforms/armv ... berry-pi-2
PINN worked. I got an alert on boot telling me some txt file could not be read. But then it installed arch no prob.Though I am surprised you are unable to get PINN to function
First sector (2048-3963204, default 2048):
Last sector, +sectors or +size{K,M,G,T,P} (2048-3963204, default 3963204): +100M
Created a new partition 1 of type 'Linux' and of size 100 MiB.
Command (m for help): t
Selected partition 1
Partition type (type L to list all types): c
Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
Command (m for help): n
Partition type
p primary (1 primary, 0 extended, 3 free)
e extended (container for logical partitions)
Select (default p): p
Partition number (2-4, default 2): 2
First sector (206848-3963204, default 206848):
Last sector, +sectors or +size{K,M,G,T,P} (206848-3963204, default 3963204):
Created a new partition 2 of type 'Linux' and of size 1.8 GiB.
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Re-reading the partition table failed.: Invalid argument
The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8).
[email protected] ~ $ mkfs.vfat /dev/mmcblk0p1
mkfs.fat 3.0.28 (2015-05-16)
/dev/mmcblk0p1: Permission denied
[email protected] ~ $ sudo mkfs.vfat /dev/mmcblk0p1
mkfs.vfat: /dev/mmcblk0p1 contains a mounted filesystem.
[email protected] ~ $ mkdir boot
[email protected] ~ $ mount /dev/mmcblk0p1 boot
mount: only root can do that
[email protected] ~ $ root
The program 'root' is currently not installed. You can install it by typing:
sudo apt install root-system-bin
Total and utterly confused as you now state you have a Raspberry Pi 1 but following a Raspberry Pi 2 Tutorial !!carsten888 wrote:3 hours working on this, stuck at step 2 from this tut.![]()
What for the life of me am I doing wrong?
2. At the fdisk prompt, delete old partitions and create a new one:
a. Type o. This will clear out any partitions on the drive.
b. Type p to list partitions. There should be no partitions left.
c. Type n, then p for primary, 1 for the first partition on the drive, press ENTER to accept the default first sector, then type +100M for the last sector.
It won't accept +100M.Command (m for help): n
Partition type
p primary (0 primary, 0 extended, 4 free)
Partition number (1-4, default 1): 1
First sector (2048-204799, default 2048):
Last sector, +sectors or +size{K,M,G,T,P} (2048-204799, default 204799): +100m
Value out of range.
Last sector, +sectors or +size{K,M,G,T,P} (2048-204799, default 204799): +100M
Value out of range.
[email protected]:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop1 7:1 0 76.7M 0 loop /snap/core/1079
loop3 7:3 0 76M 0 loop /snap/core/1222
loop4 7:4 0 76M 0 loop /snap/core/1240
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 200M 0 part /boot/efi
├─sda2 8:2 0 46.6G 0 part
├─sda3 8:3 0 229.7G 0 part
├─sda4 8:4 0 619.9M 0 part
├─sda5 8:5 0 619.9M 0 part
├─sda6 8:6 0 619.9M 0 part
├─sda7 8:7 0 619.9M 0 part
├─sda8 8:8 0 177G 0 part /
└─sda9 8:9 0 9.3G 0 part [SWAP]
sdb 8:16 1 14.9G 0 disk
sr0 11:0 1 1024M 0 rom
[email protected]:~$ sudo fdisk /dev/sdb
Welcome to fdisk (util-linux 2.29).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): o
Created a new DOS disklabel with disk identifier 0x3ee40bfb.
Command (m for help): p
Disk /dev/sdb: 14.9 GiB, 16021192704 bytes, 31291392 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x3ee40bfb
Partition type
First sector (2048-31291391, default 2048):
Last sector, +sectors or +size{K,M,G,T,P} (2048-31291391, default 31291391): +100M
Partition type
First sector (206848-31291391, default 206848):
Last sector, +sectors or +size{K,M,G,T,P} (206848-31291391, default 31291391):
Created a new partition 2 of type 'Linux' and of size 14.8 GiB.
Syncing disks.
├─sdb1 8:17 1 100M 0 part
└─sdb2 8:18 1 14.8G 0 part
[email protected]:~$ sudo mkfs.vfat /dev/sdb1
mkfs.fat 4.0 (2016-05-06)
[email protected]:~$ mkdir boot
[email protected]:~$ sudo mount /dev/sdb1 boot
[email protected]:~$ sudo mkfs.ext4 /dev/sdb2
mke2fs 1.43.4 (31-Jan-2017)
Creating filesystem with 3885568 4k blocks and 972944 inodes
Filesystem UUID: 3b427c3d-e674-490b-88e5-d0a497b78301
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
[email protected]:~$ mkdir root
[email protected]:~$ sudo mount /dev/sdb2 root
[email protected]:~$ wget http://os.archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz
--2017-02-20 15:01:33-- http://os.archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz
Resolving os.archlinuxarm.org (os.archlinuxarm.org)... 50.116.36.110
Connecting to os.archlinuxarm.org (os.archlinuxarm.org)|50.116.36.110|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://co.us.mirror.archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz [following]
--2017-02-20 15:01:33-- http://co.us.mirror.archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz
Resolving co.us.mirror.archlinuxarm.org (co.us.mirror.archlinuxarm.org)... 72.13.197.87
Connecting to co.us.mirror.archlinuxarm.org (co.us.mirror.archlinuxarm.org)|72.13.197.87|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 294803039 (281M) [application/x-gzip]
Saving to: ‘ArchLinuxARM-rpi-latest.tar.gz’
ArchLinuxARM-rpi-latest.tar 100%[========================================>] 281.15M 18.0MB/s in 16s
2017-02-20 15:01:50 (17.5 MB/s) - ‘ArchLinuxARM-rpi-latest.tar.gz’ saved [294803039/294803039]
[email protected]:~$ sudo bsdtar -xpf ArchLinuxARM-rpi-latest.tar.gz -C root
[email protected]:~$ sudo sync
[email protected]:~$ sudo mv root/boot/* boot
[email protected]:~$ sudo umount boot root
[email protected]:~$ rm -r boot root
