http://www.catb.org/esr/faqs/things-eve ... once-knew/
so useful / interesting stuff here
Though he's not exactly a reliable witness to it, as he's quite happy bending the history of the movement (if such a thing existed) to his own ends. He also advocates for causes that I can't have anything to do with. This article isn't entirely serious, but it does touch on issues removed from the esr's highly sanitized Wikipedia article: Eric S. Raymond - RationalWiki.Heater wrote:…As Eric points out, he writes about "hacker" culture.
Even more so: tear the ends of your punched paper tape into a chevron so you know which end is the Start and which is the End!scruss wrote:
So: a thing that every hacker once knew that's not on his list: draw a diagonal line across the top of your punched card deck so you can get them back in order when you drop 'em …
I'm curious. What causes is it Eric is supporting that are so objectionable? I have been reading Eric's ramblings for decades now and can't think of anything bad coming out of it.He [Eric Raymond] also advocates for causes that I can't have anything to do with.
Quite understandable. As I said above Eric speaks of the "hackers" out in the world. Not secret cloisters of the IBM business world. He says as much.I see he's decided that everything to do with record-based computing (so, IBM knowledge) is not hacking, and that everything that mattered ran Unix from even the mid 1970s.
Hey, I knew that trick. From punching out Algol programs in 1974. Not on IBM though. We had ICL 2960.So: a thing that every hacker once knew that's not on his list: draw a diagonal line across the top of your punched card deck so you can get them back in order when you drop 'em …
I'm still using AMASPZAP (and getting the reputation that goes with it). I hacked a module in IMS V12 for a production system problem with that back in November 2016. That's the closest I can get to writing machine code on the switches these days.TudorJ wrote:Ah, but what about Superzap (Dougie will know what I mean).
A 2960 in 1974 ... I thought they didn't ship till 1976.Heater wrote: Hey, I knew that trick. From punching out Algol programs in 1974. Not on IBM though. We had ICL 2960.
I guess my dad's computer bureau (Clydeport Data Management: a big orange ICL 29xx in the dockyard in Govan) was a bit fancy, then, as they had a little handheld cutter thing that made the chevron. Which I may have played with a lot as a tiny wee lad in the punchroom. Still, it was playing with the paper tape rewinder and getting my finger stuck in it that caused the most damage …B.Goode wrote:Even more so: tear the ends of your punched paper tape into a chevron so you know which end is the Start and which is the End!
Racism (the “Anti-Idiotarian Manifesto”, and other writings that link race and IQ), misogyny/MRA nonsense (such as his allegations over the Ada Initiative) and climate change denial (his noise over Climategate, followed by his total silence when the scientists were vindicated, speaks volumes) — amongst other things. No links, 'cos this is a family show, but his blog is a minefield of nope.Heater wrote:What causes is it Eric is supporting that are so objectionable?
Heater wrote:By George you are right.
